ForumindexDiverseSnick SnackDatorer/telefoner, hård- och mjukvara
Outlook-adresser
23 inlägg • Sida 1 av 2
Snacka datorer och telefoner i detta forum.
Holger (trådstartaren)
#1 » 16:33:24, 11-04-2023
Hejsan,
flera gånger om dagen får jag mail från medlemmar som behöver hjälp med sina konton.
Ibland är det mail från Outlook-adresser.
Och ibland ser de ut så här: outlook_A3E62356AE14F7E7@outlook.com
Mycket irriterande, för svarar man på dessa mail så kommer de inte fram utan bouncas av Outlook. De finns alltså inte.
Vad beror det på att dessa adresser används? Är det pga felkonfigurerade mailprogram?
/Holger
Holger
Webmaster
Webmaster
Maskin: Test
#2 » 22:54:36, 16-04-2023
https://eforum-idg.digidip.net/visit?ur ... outlook%2F
Last updated: June 18, 2021
ISSUE
After adding an email account to Outlook for Windows (Outlook 2016, 2013, 2010 versions) you may experience the following:
Your email account name shows up as outlook_[long series of letters and numbers]@outlook.com in the Folder Pane and when composing emails using Outlook for Windows.
Recipients will also receive the email from the sender with the outlook_[long series of letters and numbers]@outlook.com format.
When recipients reply to the email, the email bounces and you may receive the message “Undeliverable message when you send Internet mail in Outlook.”
This issue can occur when you register a 3rd party email address (e.g., an email address that is not Outlook.com or Hotmail.com) for your Microsoft Account and don't use Outlook.com for sending and receiving email.
If you typically use an Outlook.com account for email, this issue can occur if there are multiple aliases on the account and the 3rd party email address is the primary alias. Please see the ALTERNATIVE WORKAROUND section below.
WORKAROUND
Set up your account manually as an IMAP or POP account in Outlook.
Close Outlook
Use Windows Key + R then type “outlook /profiles” (omitting the quotes) in the Run window and hit “OK” Note: There is a space between outlook and the forward slash (/)
In the launched “Choose Profile” box, select Options > New
Type a new, unique profile name and select OK
Choose Advanced options > Let me set up my account manually.
Enter your account password, then choose Connect.
If setup fails, select Change Account Settings. Update the account information with the one you received from your email provider or from the POP and IMAP server name reference topic. Choose Connect then then select Done.
In the Choose Profile window, select Set as default profile and select OK.
Switch your alias to an Outlook.com or Hotmail.com account.
Note: If you do not have another alias, select the link on the page to create one. Choose Add email and a new alias and then choose the option Create a new email address and add it as an alias.
Go to https://account.live.com/names/Manage and sign in to your Outlook.com account.
Set your Outlook.com email as the primary alias.
In Outlook for Windows, remove and re-add the account. See the steps in this article: Add your Outlook.com account in Outlook for Windows
#3 » 08:11:04, 17-04-2023
Utmärkt, tack!
Holger
Webmaster
Webmaster
Maskin: Test
Bygert
#4 » 11:48:16, 17-04-2023
Det där beskriver ju hur man som sändare kan hindra att det skickas sådär. Men om man mottagit ett sånt mail, finns det nån lösning för att svara?
Jag har ett annat problem också. Vissa mail visas inte i outlook på datorn, de går helt enkelt inte att få upp i någon mapp. Men de finns i yahoo-appen i telefonen. Ser inget annat samband än att det är viktiga mail som behöver någon form av åtgärd.
Bygert
Maskintyp: Grävlastare
Maskin: Huddig 1160
#5 » 13:47:14, 17-04-2023
Har du koll på vad det är för outlook du har?
I outlook 2016 och 2019..
File-flik -> info -> add account -> yahooadress -> yahooappens password.
Bygert
#6 » 14:14:20, 17-04-2023
2019 Anslutet är det ju uppenbarligen eftersom de flesta meddelanden kommer in, det är enstaka som inte visas.
Bygert
Maskin: Huddig 1160
#7 » 08:39:04, 22-05-2023
Sååå jobbigt, eftersom jag inte kan svara och hjälpa
Holger
Webmaster
Webmaster
Maskin: Test
#8 » 15:05:36, 22-05-2023
Förtydliga problematiken via autosvar/bekräftelse på mottaget email lär få samma problem ..
Vart är närmaste länk eller emailadress som en människa använder sei av vid ett sådant problem?
Förtydliga med text varför dessa inte får någon kod tillbaka och att det blir samma responsproblem om dom vill ha hjälp av dei, be dom skriva in adressen manuellt i texten/meddelandet, kanske någon notis om grundproblemet också.
Skapa en egen kanal/länkad adress till detta problem med fritext i en förklaring om att deras adress inte går att kommunicera med?
Klicka på denna adress om du inte får en svarskod = förklaring/beskrivning av problemet.
Steg två, när dom skickar till webmaster? är redan försent ..
#9 » 15:16:37, 22-05-2023
Ingen fattar innebörden av "observera ange giltig emailadress", eftersom det är ett dolt problem för dessa.
använd dina skills som medmänniska/översättare och tryck dit en övertydlig text utan att slösa med ord.
Har du tillträde till registreringsförsöket? där finns den handskrivna emailadressen.
:snow: antagligen inte, det hör väl till programvaran.
#10 » 15:22:19, 22-05-2023
Bra hänvisningar Michael!
Holger
Webmaster
Webmaster
Maskin: Test
#11 » 15:23:49, 22-05-2023
Michael Meier skrev:Har du tillträde till registreringsförsöket? där finns den handskrivna emailadressen.
Nja, personen ovan kom ju inte så långt att registreringen skapas.
Holger
Webmaster
Webmaster
Maskin: Test
#12 » 15:29:56, 22-05-2023
Vart hamnar en ofullständigt registrering?
#13 » 15:33:13, 22-05-2023
Den skickas inte iväg, sparas inte och "förfaller"
Holger
Webmaster
Webmaster
Maskin: Test
Mikkel
#14 » 15:53:03, 22-05-2023
Bygert skrev:.....Jag har ett annat problem också. Vissa mail visas inte i outlook på datorn, de går helt enkelt inte att få upp i någon mapp. Men de finns i yahoo-appen i telefonen. Ser inget annat samband än att det är viktiga mail som behöver någon form av åtgärd.
Jag får samma problem ibland på min outlook-adress, mailet syns inte på outlook men om jag söker på just den avsändaren (om jag vet att jag skulle ha fått ett e-mail) så visar sig mailet, jag har trott att det beror på att Norton har blockerat, kanske har det en annan förklaring.
Mikkel
Maskin: MF35
G-son
#15 » 18:29:45, 22-05-2023
Du skulle kunna lägga in en knallorange varningsruta som visas för icke inloggade på forumet, exempelvis på registreringssidan, eller kanske med lite mer datakunskap ett varningsmeddelande som visas automagiskt när någon försöker registrera sig med en outlookadress. Löser inte problemet helt, men informerar om det till de som orkar läsa det.
G-son
