Kemppi mig svets ger dålig ström REPARERAT!!
21 inlägg • Sida 2 av 2
Diskutera svetsning här
Joe
#16 » 11:53:23, 21-10-2009
Intressant!
Vi har en äldre kempi mig på jobbet som svetsar dåligt efter en stund, ska kolla hur den ser ut inuti om det kan vara något liknande problem.
Joe
gerard23
#17 » 12:05:04, 24-02-2010
Hello to all,
i am new on the forum :grin: and first of all sorry for the englisch,but i dont speak or understand your languige :sad: .
I have also a problem with a kempi kempomat 150.
the problem is,
on the printboard the fuse blows after pushing the wirefeed switsch,the transistor bdx53 was broking.
-replaced the transistor and now blows the fuse and resistor 2E2 10W.
-wan i remove the bdx53 (dont mount it at all)from the board,the motor is running and the speed is adjustible,so i think the thyristors ar ok.wan the motor runs the relais K001 dont get tension and is not switsched.
-replaced the electrolit capacities
-on the potentiometers i have 15vdc but after pressing the switch is dropping to 11vdc (dont now or its normal)
also:
-wire feed is ok but i dont get tension on the welding wire.
-i have tested all power thyristor and power diodes
- all secundair tension on the transformer are ok
-fuse f1 ok
-bridge g002 ok
hope somone can help me in englisch,or with example on pictures
wfr gerard23
gerard23
gerard23
#18 » 00:34:57, 25-02-2010
The problem is solved :grin:
the voltage on the 15v zener(in the sqaure) was dropping to 10v wen i close the wirefeedswitsch ,
After following the 15 circuit i found the defect component "the tantalium 33uF 25V capacitor was short circuit".
after replacing the capacitor everything works fine :razz:
Bild Tillägg efter 1 minut(er):
gerard23
rallejohansson (trådstartaren)
#19 » 14:11:32, 18-03-2010
Ett tillägg . :grin:
Råd :BYT TRÅDLEDAREN !
har bytt trådledare ( vajern ) till en ny och dessutom nytt munstycke och också gashylsan .
Detta gjorde att tråden nu löper riktigt bra , den hade tidigare en tendens att knycka lite ibland .
Att byta till eurohandtag skulle ha blivit dyrare än vad vi lagt ut på svetsen,så det blev att reparera istället
Köpte Kemppidelar och servicegubbarna sade att mitt svetshandtag hade modifierats av nån bysmed kanske , men nu är allt ok . :smile:
rallejohansson
polo_td
#20 » 08:46:24, 15-08-2014
Det värsta som kunde hända just nu hände!!
Min Kempi svets RA-230 med FU-10 matarverk la ihop ögonen bara så där...
Som tur är så har vi i http://www.dieselclubsweden.se en samarbetspartner just för denna typ av fel.
DN elektronik i Mölnlycke.
Dennis Nilsson fick i uppdrag att hitta felet.
Jag tog ut mitt kretskort och stack till Dennis.
Dennis provade och mätte.
Bytte bland annat en tyristor.
Dennis ringde och sa att kortet var klart.
glad som faan åkte jag dit och hämtade upp kortet.
kopplade in detta men..... svetsen var fortfarande helt död.
Min värsta tanke uppenbarade sig.
Skulle min gamle trotjänare faktiskt ha gjort sin sista svetsloppa??
Klockan var nu 19.00 på kvällen, Ringde Dennis som precis kommit hem och förklarade.
Dennis säger då att jag kommer och tittar på den direkt.
va!!! skojar du sa jag.
Nej kunden skall vara nöjd.
jaja, en timma senare stod Dennis på min uppfart med alla möjliga instrument.
Lite drygt 2 timmar senare, en massa mätande och testande så fixade han den.
klockan 22.00 startade svetsen smile
Den lycka att få igång svetsen igen går knappt att beskriva.
En stor sten föll.
Det är just detta som gör DN elektronik och Dennis så unik.
Att jag rekommenderar DN Elektronik tror jag inte att ni behöver undra över.
Ni som behöver laga ett kretskort/felsökning etc Ring Dennis.
Hälsa från mig.
http://dn-elektronik.se/
Dennis :0727401020
Glöm inte att bli medlem på dieselclubsweden. wink
Thomas
polo_td
borisson
#21 » 20:11:30, 29-09-2014
Har köpt en gammal mig en kemppi migomag 153.
Visuellt ser den grymt fin ut och har inte en repa! Dock verkar den
Inte ha någon riktig kräm. Mätte volt mellan jord och munstycke och värdet ändras beroende på hur strömställaren är mellan 14.2 (läge 1)och 19.2 (läge 4)är detta tomgångsspänning? Den är ju på inte någon storverk men borde ju kunna bränna in i en 3 mm plåt tycker jag. Blir bara en lös kaka. Är kolsyra till den! Har prövat att öka och minska gasen.
borisson
Maskin: Merlo roto 4521
Wille 445
Volvo L30B
JCB 530b
Återgå till Svetsning
