ja-bond77 skrev:Aaah!
But... that is just plain lazy...
I would trade for more reach any day if it just costs some small coupling difficulties. You don´t always have to fill the bucket/grab fully... I´ve heard...
Not so much lazy JA as
easier,
but as you and Jörgen both quite rightly say -
much better reach !!
Plus as you say, you don't have to fill that big old grab with every 'bite'
It's a great tool for loading loose materials with and is I believe a 'digging' grab, but at 4 ft wide, the
ground would not want to be too hard!!
I have a lot of 'loose'/pre-dug to re-handle so it will be very useful for loading this out into my dumper!
I have also reduced/eliminated the risk of pipe damage, on the grab, by
fitting QCs to the rotator,
so the pipes are off, out of harm's way, whilst it is being 'juggled about', getting it on there
and I wanted to 'borrow' the pipes for other things!!
I did eventually try the grab on the way around it was intended ........
I'd been intending to wrestle the grab on to her for a while, to bag up a load of 20mm to dust and 40mm clean left over from a couple of 20 ton loads that'd been sat about for a while and were in the way for a (garden type) shed move.
Having sussed the 'right way' round to hitch her up,
from pix of others I'd found on the net (and also discovered that this is a
digging grab as opposed to a simple loading grab), I set about trying to get the damned thing on.
Even with my
'patent' wooden blocks supporting the hitch, it was still a little bitch!!!
After what seemed like
some considerable time and effort it was on and I took somebody's suggestion of laying it over on its side, to pipe it up.
You want fingers like the Madagascan Aye Aye Lemur ........
.........to get at the screw on QCs, with the crowd
ram closed against the dipper - lot of room - NOT !!!!!
But it was on eventually and hanging as it was meant to!
For such a lump
she handled it well - as long as I remember the axle locks, that is!!
Having got myself parked where I could get at all I needed to reach, I thought it prudent to drop that old blade a tad closer to the deck, just to keep her from nodding about too much !!
Jakie got woken from his slumbers to hold the bags for his
big bro and shift 'em out the way, when they eventually got filled - metre bags and a 4 ft grab spell
over-spill !! (until I got the drop on keeping it to one side of the grab with some careful positioning !!)
Sure beats the hell out of filling nine bags by hand though - ended up with eight after the one spewed it guts, when it got picked up and had to reload it into a fresh bag - bloody bio-degradable bags!!!!!!
I eventually got quite adept at closing it and raising with it, to just scrape the deck of 'loose'. Deffo would've been easier with the controls the right way round though!!!!!!!
First time that patch of ground has seen the light of day in close on 4 years!!
No sooner was it clear-ish than another 20 t load, or two, of stone appeared on it,
et sec, etc. !!
Next time though the pipes are gonna get crossed over, as close was the wrong way round and kept catching me out.
Beginning to wonder whether the pipes ought to be the other side of the pick up, so' I could feed 'em through the swivel, keeping 'em out the way a bit better and they'd be the 'right way round' - crowd to close.
Just Googled a load of 'Dremas on Heavy Cherry and sure enough, they've all got the pipes out front !!
Next question was .............. do I pull the
pin, or undo the
bolt???????
Still have not sussed why that
bracket is on such a cock eyed angle either??
The lil' guy in the last pic below, has just seen the amount of space available to get at the QCs, next to the crowd ram!!!!!!!!!
Think I'll put them on first next time, before I
lock off the ram in the closed position!!
After Jakie'd parked all the dumpies, once filled, I had to find 'em all a home.
Past experience has taught me that the straps on these things are not the greatest of items,
so thought it prudent to get 'em all on pallets,
before trying to relocate 'em to an 'out the way' (for now) spot, with the least jiggling and stress possible to 'em!
Similarly experience has taught me that these bag's straps do not like forks
and are much less likely to 'let go', hung on some more
strap friendly, 'softer' tubes!!
Doing it this way is also a damned sight easier than trying to
thread the tubes through the straps,
with them
slid on the forks.
These are too small for 'the 'Drema forks' anyway,
but I do have some bigger ones that will fit them.
Was interesting that, at full stretch, placing these, the 'Drema actually sounded as though she was noticeably 'working',
possibly the first time she'd actually 'grunted' a bit and she'd done some pretty decent lifts to that point!
