Druid's 'Drema's Druidfab Attachments !!
1743 inlägg • Sida 116 av 117
V8Druid (trådstartaren)
#1726 » 22:31:12, 30-03-2023
gute84 skrev:keep the hitch grease all the time just a just a suggestion :grin:
and keep in the car when not used peole people do nick them
a friend got her cat stolen in Cardiff a couple of moths ago in daylight
Got some nice graphite/moly rich spray chain lube that'll do the job nicely Gute :thumme:
found this on ebay which looks to be the same fitting for a 'chop' ... a neighbour has a Freelander two and i'll have to have a look at theirs to size it up
https://www.ebay.co.uk/itm/285204289229
been a lot of CAT.s being pinched around here lately ... especially from multi storey car parks ..... was a big spate about 10 years ago too when they were fetching huge money for scrap
If it's got tracks, wheels, t*ts, or an engine, at some point it's gonna give you trouble!! :uupps:
V8Druid
Ort: Druid central, just East of Pandy, Nr. Abergavenny, S. Wales, UK, 3rd rock from the Sun
International
Maskin: '99 15 tonne Hydrema Weimar M1500 compact wheeled excavator with Druidfab VA-r tilt rotator (rototilt)
'86 JCB 3CX SITEMASTER Extradig --SOLD
2002 JCB 8015 - 360 excavator
'97 6 tonne swivel skip Thwaites dumper
3 tonne Tico Humperdumper
Fleming Manor Micron 1/2 ton walking excavator
Skru'are
#1727 » 23:39:30, 30-03-2023
gute84 skrev:a friend got her cat stolen in Cardiff a couple of moths ago in daylight
would have been worse if it was the mouse :vissla:
Skru'are
gute84
#1728 » 00:54:51, 31-03-2023
for modifying to accept a jaw ? is that just a Ball & Pin ?
gute84
International
Maskin: en mängd skrot
Burträskarn
#1729 » 08:00:37, 31-03-2023
Got the same type on the Vectra. It comes off once a year, and thats at the MOT. Here the entire traficsafety system depends on that bloody thing is properly removeable. I hate it! next time I trade cars, I'll cut a substansial number of thousands off the price, if it has been defiled with a detatchable hitch
Burträskarn
Maskin: Deutz 10006
MF35X
Hydromac 115
Atlas Copco XAS85
Disco1
Scania P280
gute84
#1730 » 11:59:48, 31-03-2023
Burträskarn skrev:Got the same type on the Vectra. It comes off once a year, and thats at the MOT. Here the entire traficsafety system depends on that bloody thing is properly removeable. I hate it! next time I trade cars, I'll cut a substansial number of thousands off the price, if it has been defiled with a detatchable hitch
hopefully thousands of swedish krona :grin:
gute84
International
#1731 » 19:03:42, 31-03-2023
gute84 skrev:for modifying to accept a jaw ? is that just a Ball & Pin ?
Can be either Gute .... straight forward Ball or Jaw or a combi unit or a jaw with a ball type pin it
this is what i have on the back of my P38
I have one of these on the back of my Discovery D1
one I mounted for a friend to tow a vintage bus with
conventional 50mm ball coupling -- could also used to get a 2" version of this - 50mm will not go on a 2" but a 2" will go on a 50mm unit (and come off all too easily too if confused)
all mount on a 3.5" ctr plate which is what I would want to attach to the alternate removable unit with 3 differing levels like I have on the back of my P38 Range Rover ..... all bases covered :thumme: with a combi or jaw and pin :grin:
V8Druid
International
gute84
#1732 » 21:12:28, 31-03-2023
removed my hitch completely from my disco 2 it was the same typ as your p38 it acted like a boat anchor in the hills and forest :grin:
the pin ones is not very common in sweden on cars more on tractors and lorries
the one in the first picture are some sort standard size? been looking at a trailer to buy that has loop on it dont know the correct name of it and need to change my hitch on my sprinter to work
gute84
International
#1733 » 23:28:06, 31-03-2023
gute84 skrev:removed my hitch completely from my disco 2 it was the same typ as your p38 it acted like a boat anchor in the hills and forest :grin:
Dixon bate combi Gute
https://www.ebay.co.uk/itm/320827808808 ... R_aVnpjnYQ
here is a jaw and pin type
https://www.ebay.co.uk/itm/165831186974 ... 0667.m2042
there are also these for a ring hitch
Bradley autojaw - I have a couple of these without the ball
https://www.trailer-center-discount.com ... -ball.html
you open it, reverse back so the ring hits the back of it and it closes automatically
https://www.wilmond.co.uk/autojaw-pin-a ... aj351.html
see if I can find some pix of the ones I have :thumme:
V8Druid
International
#1734 » 23:56:20, 31-03-2023
here you go Gute
Bild Bild
Bild Bild
Bild Bild
Bild Bild
Bild Bild
V8Druid
International
gute84
#1735 » 01:22:51, 01-04-2023
i need a hitch i can weld on
gute84
International
#1736 » 13:11:46, 01-04-2023
gute84 skrev:Bild
never seen one like that before :uupps:
make up a receiver plate at 3.5" ctr.s with two M16 studs tapped and welded into it, then weld the receiver to your tow bar with the studs facing rearward .. then you can bolt on any conventional hitch you like
or
make up a slider mount to pin on anything you want ... will get a pic of what I made for the back of my Discovery D1 for you
V8Druid
International
#1737 » 15:16:30, 01-04-2023
here is something similar I made for my little jakieB Gute, but bolted to the blade to get the height right and make removal simple
V8Druid
International
#1738 » 15:47:55, 01-04-2023
chassis for the skip
then made it a.n.other body too
last bits .. top steel lip and tail gate
just need to fit the mudguards, which have been sat here some time :huh:
V8Druid
International
#1739 » 18:59:47, 01-04-2023
here you go Gute ... back of the P38 RR
and the one on the back of my D1
V8Druid
International
#1740 » 18:47:13, 09-03-2024
Hi all .. can't believe it's 11 months since I was last in here :uupps: :uupps:
tempus fugit as they say :vissla:
must be a lot happened since I was last in here :blinkis:
hope everyone is OK :wave: :thumme: :thummar:
will have to have a look back to see and what I've been up to for some updates :vissla:
V8Druid
International
