O & K RH6 Manual
3 inlägg • Sida 1 av 1
rannoch (trådstartaren)
#1 » 04:49:23, 15-09-2014
Have just copied my circa 1982 O & K RH6 manual. These are pretty sparse on the internet so thought it might be of use to someone here.
If printing it double sided make sure to specify that it is landscape and flip the page up. It should read properly then with info on the top page referring to stuff on the bottom page.
Content is - Operation, Working Equipment, Servicing/Maintenance, Hydraulic systems, Gears/ Slew Ring, Brakes, Travelling Gear, Scheduled servicing, Repairs - undercarriage - hydraulic cylinders, troubleshooting, Parts list including wiring diagram. Cheers
File uploaded to the download-area /Holger
rannoch
1 inlägg
Maskin: O & K RH6
Holger
#2 » 09:33:03, 15-09-2014
Thanks a lot!
I have uploaded the files here:
O&K RH 6 manual
O&K RH 6 reservdelar
Holger
Webmaster
Webmaster
Maskin: Test
Ohranja
#3 » 14:31:58, 15-09-2014
Hi,
Thank you for this new one! I have O&K RH 6 year model 1990 and I am trying find operation instructions etc. to my machine. If anyone have any information where I could find those, could you please send write it to the forum or send a message.
Br jari
Ohranja
1 inlägg
Suomi Finland (finska)
Maskin: O&K RH6 and SAME Mercur 85
Användare som besöker denna kategori: Google Adsense [Bot] och 5 gäster
