| Author |
Message |
selmir_Bosnia
Mer än 100 inlägg
Posted: 20:24:23, 12-09-2011
Post: #46
One intersting thing. Pleas pay some attention to firs picture in my last post, where I showed the T40 front axle construction? Watch that picture ver y carefully and try to find out what's "wrong" with axle construction? Well, it's not "wrong" like it's something bad (in fact, it's very good!), but T40 axle is quite uniquie in one detail. Can somebody see why? Like i sad, pay attention to contruction |
Back to top :: Tillbaka
ErikPetersson
Mer än 500 inlägg
Maskin: PelJob EB406 -98 BM 650 -73 Barford SXR 3000 -00 Velsa 8t Tippkärra Åkerman EW 150 C 1996 nr 538
Posted: 20:52:22, 12-09-2011
Post: #47
| Citat: | | Well, it's not "wrong" like it's something bad (in fact, it's very good!), but T40 axle is quite uniquie in one detail. |
Don`t know anything about 4wd frontaxels, but is it adjustable in beam/vith?? or maybe this is common?
Anpassade citat-koden /Holger |
selmir_Bosnia
Mer än 100 inlägg
Posted: 21:16:18, 12-09-2011
Post: #48
LTZ T40 has an adjustable front axle, you can adjust it's width (you can do it on Belarus MTZ tractor too). That's one pretty strange thing on this axle, but there's one to - the importatant one. Here, a little help - It has something to do with differential. |
ja-bond77
Maskin: SampoR2065-07 Valtra 8150 hitech-01 Lännen 860 S -00 Case IH 1394-4 -86 David Brown 1212 -81 Ford Major Kockum 414B -82
Posted: 06:39:24, 13-09-2011
Post: #49
Thanks for the post. It seems like part #18 and #25 is out of the ordinary, no angular coggwheels inside that differential... |
selmir_Bosnia
Mer än 100 inlägg
Posted: 14:08:17, 13-09-2011
Post: #50
Jeah, that's right. T40 has no "real" diferential. |
Oskar B
Mer än 500 inlägg
Maskin: Allis Chalmers TL14D David Brown PRAIRIE IC/1 Cropmaste Volvo Bm 280 (tröska) Ford Fordson Power Major Massey Ferguson 186 (tröska) Volvo T21
ja-bond77
Posted: 08:23:37, 22-01-2012
Post: #52
Lastmaskin! Felpost! |
Larsson115
Mer än 100 inlägg
Maskin: Volvo EW160 Komatzu PC20
Posted: 13:23:24, 24-01-2012
Post: #53
Finns det maskiner med längre huv än den? |
 Häv och Gräv!
Bengt Erik Eriksson
Mer än 500 inlägg
Maskin: hemma : AVANT 218 Wheelhorse GT14-73 tidigare:BM BOXER I framtiden: Farmall M.
www.björnbacka.se www.esnservice.n.nu
Posted: 20:40:54, 10-07-2012
Post: #54
En helt unik traktor! BUKH 906 En 100hk BUKH 6:a på dutra chassie buggd i ett ex 1965 och skrotad 1975 men återskapad av en annan Dutra men original kopplingshuset!
Läs mer om Danmarks stolthet här! |
Hool
Mer än 10 inlägg
Maskin: Black & Decker :(
Posted: 21:25:02, 10-07-2012
Post: #55
En av mina favoriter.
Big Bud 747.. Kanske inte sådär jätteovanlig men lite annorlunda än standard iaf..
Rätt stöddig size på den men
http://www.youtube.com/watch?v=_UTbYnKEjcY
Finns nog effektivare grejer nuförtiden.. |
Conny Kolsjö
Mer än 500 inlägg
Maskin: Åkerman H7C, H16D Hanix H26B Mattsson 266S Hough H-120C Clark Michigan 75B Kockum KL420 Moxy 6227B, MT27 Volvo FL6 Landsverk L77 Case 1150B Givetvis avatarbildens Nordverk Puma från -61 Samt diverse annat.
Medlems nummer 1528
Posted: 22:44:17, 10-07-2012
Post: #56
Hool skrev: | Kanske inte sådär jätteovanlig
Jo den är mycket ovanlig då det bara finns EN!!!!!!
Och vad skulle vara effektivare??? En morden på 5-600 hk eller den där som är ned ställd till 900 hk från original effekten på 1100????
Bekvämare ja men effektivare nej |
Bengt Erik Eriksson
Mer än 500 inlägg
Posted: 22:49:08, 10-07-2012
Post: #57
Läste om bb 747att de kollade upp bakaxeln efter 10000h och upptäckte att den varit felmonterad! |
Hool
Mer än 10 inlägg
Posted: 22:52:16, 10-07-2012
Post: #58
Conny Kolsjö skrev: | Hool skrev: | Kanske inte sådär jätteovanlig
Det sitter ju bara en krok bakpå den där.. Ingen hydraulik.. Sedan 900 häst javisst men då traktorn allena väger 52 ton(?) så ..
En modern eropeisk jordbrukare med en rejäl växellåda osv är ju betydligt lättare och då finns det mos över att dra saker och ting..
Iaf enligt min syn på saken..
Sedan hur ball är det egentligen med 2takt dieslar på 16liter? |
Conny Kolsjö
Mer än 500 inlägg
Medlems nummer 1528
Posted: 23:08:21, 10-07-2012
Post: #59
ÖÖÖööö Hool man har ingen användning för hydraularmar på en så stor dragare Och hydraulik finns det så det räcker. Är säkert minst 6 dubbelverkande uttag bak på den Hool skrev: |
Öööö Grund kurs i drag lära för traktorer då Du kan inte överföra mer än 26 hk per ton traktor till marken i drag kraft |
Perjos
Mer än 100 inlägg
Maskin: Same Centurion 75 Farmall B450 -62 Farmall EMD50 -54 Ih B414 med kran och skogskärra Fiat 100-90 -86 MF 203 Traktorgrävare David Brown Cropmaster Svedala DS3 väghyvel
Posted: 23:19:15, 10-07-2012
Post: #60
Hool skrev: |
Eeeh, ganska ballt faktiskt! |
