ForumindexAdministrativtNyheter
Forumetikett för nya medlemmar och gamla rävar
14 inlägg • Sida 1 av 1
Nyheter rörande detta forum och service-sajten generellt.
Holger (trådstartaren)
#1 » 13:12:48, 14-10-2014
Hittade detta på nätet och tycker att det är en bra grej att läsa igenom lite då och då!
Online discussion forums are usually interesting and engaging because of the people who make up the membership base. However for anyone completely new to the scene, online communities can sometimes seem like a daunting mix of acronyms and inside jokes. With this post we hope to be able to give anyone new to forums or may be not as tech-inclined the basics on how get started off on the right foot. So if you’ve always wanted to take your hobbies and passions to the next level by joining an online forum but were always afraid of the pitfalls, here are some quick and easy tips:
:arrow: It’s OK to lurk, in fact use this time after making a screen name to look around and familiarize yourself with all the areas a forum offers.
:arrow: Find and read the forum’s posted rules, sometimes they are presented during registration, other times they may be posted in a sticky.
:arrow: If you have a burning question it’s OK to start off by posting it, but also look for an area for “introductions” if there is one available, introduce yourself and usually you will be met with welcomes. You may find that your questions may be met with more answers and engagement after introducing yourself as well.
:arrow: Remember the point above about familiarizing yourself with the forums various areas? They’re split up that way for a reason, make sure you are posting your topics and questions in the appropriate areas.
:arrow: Don’t sweat the inside jokes and shorthand that other members may have with each other, that kind of camaraderie comes naturally as you engage the community more over time.
:arrow: A forum isn’t a YouTube comments section, if you intend to be a member of the community it’s probably best to not attack anyone needlessly. Diplomatic, intelligent responses usually prevail.
:arrow: Help other newbies! Even if you joined a few weeks ago you probably have more experience than someone that joined yesterday. If you see a newbie not being helped with some basic stuff, and you know the answer, helping them out is a good way to promote a healthier forum.
Holger
Webmaster
Webmaster
Maskin: Test
63an
#2 » 14:14:04, 14-10-2014
Ibland har man tur! Ska köpa triss ikväll :idee: Man kan ju inte "english" but you are Welcome! :vissla:
63an
#3 » 14:32:12, 14-10-2014
Online diskussionsforum är oftast intressanta och engagerande på grund av de människor som utgör medlemsbasen. Men för den som helt ny på scenen kan forum ibland verka som en svår mix av akronymer och interna skämt. Med detta inlägg hoppas vi kunna ge alla nya eller kanske inte så tekniskt kunniga grunderna om hur man kommer igång på rätt sätt. Så om du alltid har velat ta dina hobbies och passioner till nästa nivå genom att gå med ett forum men alltid varit rädd för fallgroparna, här är några snabba och enkla tips:
:arrow: Det är OK att bara läsa. Använda tiden efter att du har blivit medlem till att titta runt och bekanta dig med alla de områden som ett forum erbjuder.
:arrow: Hitta och läs forumets regler, ibland visas de under registreringen, andra gånger kan de publiceras i en speciell tråd.
:arrow: Om du har en brännande fråga är det OK att börja med att lägga ut den, men leta också efter ett område för "introduktioner", presentera dig själv och du kommer att välkomnas. Du kanske upptäcker att dina frågor besvaras med fler svar och engagemang efter att du har introducerat dig.
:arrow: Kom ihåg punkten ovan om att bekanta dig med olika forumområden. De delas upp av en anledning, se till att du lägger upp dina ämnen och frågor i lämpliga områden.
:arrow: Låt dig inte irriteras av interna skämt och förkortningar, som andra medlemmar kan ha med varandra. Engagera dig och den typen av kamratskap kommer med tiden.
:arrow: Ett forum är inte som en kommentarfunktion hos YouTube, om du tänker vara medlem i forumet är det nog viktigt att inte attackera någon. Diplomatiska, intelligenta svar är viktiga.
:arrow: Hjälp andra nybörjare! Även om du gick med för några veckor sedan har du förmodligen mer erfarenhet än någon som gick med igår. Om du ser en nybörjare som inte får hjälp med en del grundläggande saker, och du vet svaret: att hjälpa dem är ett bra sätt att främja ett sundare forum.
Holger
Webmaster
Webmaster
Maskin: Test
#4 » 14:35:52, 14-10-2014
Men för den som helt ny på scenen, kan communities ibland verka som en svår mix av akronymer och interna skämt.
Med detta inlägg hoppas vi kunna ge alla nya till forum eller kanske inte så tekniskt lutande grunderna om hur kommer igång på rätt fot.
Så om du har alltid velat ta dina hobbies och passioner till nästa nivå genom att gå med ett online-forum men alltid har varit rädd för fallgroparna, här är några snabba och enkla tips:
:arrow: Det är OK att läsa utan att säga något, Det är helt okej att titta runt och bekanta dig med alla de områden som ett forum erbjuder.
:arrow: Hitta och läs forumets inlagda regler, ibland de presenteras under registreringen, andra gånger kan de publiceras i en klistrat inlägg/tråd.
:arrow: Om du har en akut fråga det är OK att börja med att lägga ut den, men också leta efter en tråd för "medlemspresentation" om det finns en tillgänglig, presentera dig själv och oftast kommer du att mötas med välkomnande.
Du kanske upptäcker att dina frågor får fler svar och mer engagemang efter att du har introducerat dig själv också.
:arrow: Kom ihåg punkten ovan om att bekanta dig med forumen olika områden? De delas upp på så sätt av en anledning, se till att du lägger upp dina ämnen och frågor i lämpliga områden.
:arrow: Inte använda de interna skämt och förkortningar, som andra medlemmar kan ha med varandra, den typen av umgänge kommer naturligt när du engagerar dei mer i forumet med tiden.
#5 » 14:36:44, 14-10-2014
äh, skit också, TVÅ tolkningar gör ingen skogsduva torr...
#6 » 14:37:17, 14-10-2014
:mrgreen:
Holger
Webmaster
Webmaster
Maskin: Test
#7 » 14:38:50, 14-10-2014
och sedan t appade jag två punkter i översättningsproceduren :ohnej:
#8 » 14:39:58, 14-10-2014
Låt 63an leta!
Holger
Webmaster
Webmaster
Maskin: Test
#9 » 14:47:13, 14-10-2014
I have sixty threes lurking in the reeds :insomnia:
jörgen.ottosson
#10 » 17:44:44, 14-10-2014
...is it season. :desperado:
Deus ex machina
jörgen.ottosson
Maskin: sandvik sl-350
liebherr a500s
scania lbs 140
KL 121B
#11 » 21:23:02, 14-10-2014
Den där texten skulle slumpmässigt hamna som inlägg lite varstans hela tiden....så man får lite påminnelse. :mrgreen:
#12 » 09:06:09, 15-10-2014
:mrgreen:
Bilden räcker!
Holger
Webmaster
Webmaster
Maskin: Test
Fredrik_
#13 » 10:57:19, 15-10-2014
Min dator vill inte visa någon bild, inte via länk heller...
Fredrik_
#14 » 11:28:29, 15-10-2014
Bättre nu?
Holger
Webmaster
Webmaster
Maskin: Test
Återgå till Nyheter
