Rent konfigurerbart så har jag nu:
"WAN VLAN 100 on lagg0 (WAN)"
Frågan är om det funkar i verkligheten och inte bara som konfiguration...
Startup configuration:
; J9088A Configuration Editor; Created on release #R.11.07
hostname "ProCurve Switch 2610-48"
trunk 49-50 Trk1 LACP
snmp-server community "public" Unrestricted
vlan 1
name "DEFAULT_VLAN"
untagged 1-47,51-52
ip address dhcp-bootp
no untagged 48,Trk1
exit
vlan 4000
name "WAN"
untagged 48
tagged Trk1
exit
spanning-tree Trk1 priority 4
ProCurve Switch 2610-48(config)# show spanning-tree
Multiple Spanning Tree (MST) Information
STP Enabled : Yes
Force Version : MSTP-operation
IST Mapped VLANs : 1-4094
Switch MAC Address : 001ffe-71cb80
Switch Priority : 32768
Max Age : 20
Max Hops : 20
Forward Delay : 15
Topology Change Count : 3
Time Since Last Change : 10 secs
CST Root MAC Address : 001ffe-71cb80
CST Root Priority : 32768
CST Root Path Cost : 0
CST Root Port : This switch is root
IST Regional Root MAC Address : 001ffe-71cb80
IST Regional Root Priority : 32768
IST Regional Root Path Cost : 0
IST Remaining Hops : 20
Root Guard Ports :
TCN Guard Ports :
Protected Ports :
Filtered Ports :
| Prio | Designated Hello
Port Type | Cost rity State | Bridge Time PtP Edge
1 10/100TX | Auto 128 Disabled |
2 10/100TX | Auto 128 Disabled |
3 10/100TX | Auto 128 Disabled |
4 10/100TX | Auto 128 Disabled |
5 10/100TX | Auto 128 Disabled |
6 10/100TX | Auto 128 Disabled |
7 10/100TX | Auto 128 Disabled |
8 10/100TX | Auto 128 Disabled |
9 10/100TX | Auto 128 Disabled |
10 10/100TX | Auto 128 Disabled |
11 10/100TX | Auto 128 Disabled |
12 10/100TX | Auto 128 Disabled |
13 10/100TX | Auto 128 Disabled |
14 10/100TX | 200000 128 Forwarding | 001ffe-71cb80 2 Yes No
15 10/100TX | Auto 128 Disabled |
16 10/100TX | 200000 128 Forwarding | 001ffe-71cb80 2 Yes No
17 10/100TX | Auto 128 Disabled |
18 10/100TX | Auto 128 Disabled |
19 10/100TX | Auto 128 Disabled |
20 10/100TX | Auto 128 Disabled |
21 10/100TX | Auto 128 Disabled |
22 10/100TX | Auto 128 Disabled |
23 10/100TX | Auto 128 Disabled |
24 10/100TX | Auto 128 Disabled |
25 10/100TX | Auto 128 Disabled |
26 10/100TX | 200000 128 Forwarding | 001ffe-71cb80 2 Yes No
27 10/100TX | Auto 128 Disabled |
28 10/100TX | Auto 128 Disabled |
29 10/100TX | Auto 128 Disabled |
30 10/100TX | 200000 128 Forwarding | 001ffe-71cb80 2 Yes Yes
31 10/100TX | Auto 128 Disabled |
32 10/100TX | Auto 128 Disabled |
33 10/100TX | Auto 128 Disabled |
34 10/100TX | Auto 128 Disabled |
35 10/100TX | Auto 128 Disabled |
36 10/100TX | Auto 128 Disabled |
37 10/100TX | Auto 128 Disabled |
38 10/100TX | Auto 128 Disabled |
39 10/100TX | Auto 128 Disabled |
40 10/100TX | Auto 128 Disabled |
41 10/100TX | Auto 128 Disabled |
42 10/100TX | Auto 128 Disabled |
43 10/100TX | 200000 128 Blocking | 001ffe-71cb80 2 Yes No
44 10/100TX | 200000 128 Blocking | 001ffe-71cb80 2 Yes No
49 100/1000T | Auto 128 Disabled |
50 100/1000T | Auto 128 Disabled |
51 | Auto 128 Disabled |
52 | Auto 128 Disabled |
Trk1 | 200000 64 Forwarding | 001ffe-71cb80 2 Yes Yes
ProCurve Switch 2610-48(config)# show config
trunk 45-48 Trk1 LACP
vlan 1
name "DEFAULT_VLAN"
forbid 43-44,Trk1
untagged 1-42,49-52
no untagged 43-44,Trk1
exit
vlan 100
name "LAN"
forbid 44
untagged 43
tagged Trk1
exit
vlan 4000
name "WAN"
forbid 43
untagged 44
tagged Trk1
exit
ekstam skrev:Slå på portfast för spanning-treen på de portar som inte switchar paket, t.ex. dom mot din brandvägg (så länge du inte tänker brygga något interface där). På HP verkar det vara 'spanning-tree port admin-edge-port'
ekstam skrev:Annars kommer din port (när länken på den tänds) stå och vänta i 20 sekunder innan trafik kommer forwarderas på den.
