SAJO UF 54 1950s- NEED HELP
5 inlägg • Sida 1 av 1
emk5071 (trådstartaren)
#1 » 22:14:43, 07-10-2018
[/img]Hello,
I have recently purchased a SAJO UF 54 mill and need some help understanding the machine. It is my first mill and I want to learn everything on and make sure everything is in good order before running it. The one thing I can not figure out right now if the table. It has a table which can rotate 45 degrees in either direction but I can figure out how to rotate it. There are 2 studs on each side under the table which I believe are to hold it from rotating. When I take the studs out which are threaded I can see pins behind them which move some when I attach a magnet to them. The problem is that I am not sure if those pins lock at 0 degrees and I need to screw the studs in further to unlock the pins or if i need to remove the studs to allow the pins to come out some which would allow the table to turn. I have tried both and have pulled and pushed on the end of the table but neither works. Does anyone have one of these mills or a manual for them which can help
Thanks in advance!
PS I am american originally now living in Sweden which is why I write in English. I can read and speak Swedish no problem but it is still difficult to write what I am trying to explain here, sorry for that. Every Swede I know is fantastic at English so I am sure it is not a problem
emk5071
Maskin: Valmet traktor o Sajo Fras
QV_
#2 » 23:06:13, 07-10-2018
QV_
Maskin: er:
Yanmar YB401W -92
Benford 3000 -99
Atlas copco VT6-DD -65
#3 » 09:52:17, 08-10-2018
Tack så mycket QV_
I had a manual similar to this one but not as good. This helps with many things but I do not find anything regarding rotating the table however.
emk5071
QV_
#4 » 20:11:56, 08-10-2018
Titta på sid 24 och 26 punkt 4.
QV_
Maskin: er:
Yanmar YB401W -92
Benford 3000 -99
#5 » 09:12:00, 09-10-2018
I see them on the document, those are the studs I was referring to. When those are loose I should be able to just push the table to turn it?
emk5071
