Hako 522 diesel info
142 inlägg • Sida 8 av 10
jeng
#106 » 21:19:25, 19-05-2016
Däcken är dim 28x9-15 vilket ska vara samma som 240x70-15. Kort kommer
jeng
Maskintyp: Kompakttraktorer
Maskin: bolens 1254 på väg att elkonverteras
Hakotrac D522
jeng
#107 » 21:28:52, 19-05-2016
jeng
Hakotrac D522
Nicklas1981
#108 » 14:08:10, 15-09-2016
Hej! Vet ni om det är samma koppling och urtrampningslager till en bensin? Börjar få kopplongsstrul på min hako med en lombardini bensinare!
Nicklas1981
Maskin: Hako
Dacia Duster
TomppaHe
#109 » 08:28:45, 22-09-2016
Hello,
I hope it's ok to write in english as I can't swedish (can only understand some) and I'm guessing not that many of you could read finnish :)
I just though about saying "Thank you" to all of you who have shown your Hako and shared information on this site. It has been very helpful for me after I bought one about a year ago.
In the winter I started building a front loader to make it more useful instead of being just a toy. I finished first version in the spring but it wasn't powerful enough to lift more than an empty bucket. That was because original hydraulic pump was only pushing 40 bars of pressure and in my calculations I thought it could push some more. I had to fit a new pump and make a new oil tank, then add rear weight and fill the rear tires with salt water. I was also able to move front axle a little forward that helped a lot with the balance. After that it has proven that a mini-tracktor from 60's can still be a useful tool in small scale working. Until now I have spread two truck loads of soil and one load gravel that would have been too much for me with just a shovel and wheelbarrow or at least taken a lot longer time. Couple of pictures for your joy :)
Hälsningar, Tomi
TomppaHe
Suomi Finland (finska)
Maskin: Hako D522
JohnOlof
#110 » 09:37:59, 09-10-2016
Nicklas1981 skrev:Hej! Vet ni om det är samma koppling och urtrampningslager till en bensin? Börjar få kopplongsstrul på min hako med en lombardini bensinare!
Kopplingsdelarna och urtrampningslagren som jag nämnt i tråden är till min Hako med Lombardini-bensinare. Gissar att det är samma i båda modellerna. I ZF-katalogen finns iallafall bara en typ nämnda.
JohnOlof
Maskin: TGB 11, Volvo BM 650
KrAZ 255, Lokomo 928 T
KL-130, KL-520, Hakotrac v490
jeng
#111 » 21:21:12, 09-10-2016
TomppaHe:
Nice work! I have one with old front end loader, that I resently added a tilt cylinder to. How did you move the frontaxle?forward? Could you show a closeup?
Regards jonas
jeng
Hakotrac D522
TomppaHe
#112 » 12:20:01, 10-10-2016
Thanks Jonas.
You know how the front support clamps over the big shaft that front axle is mounted on? I removed the original support and made a new one out of some sturdy 20mm steel. The new one has a pin that goes INSIDE the shaft allowing axle to slide forward. Then just added a spacer behind the axle and lengthened the steering arm. It was really simple after I figured it out. Mine was earlier modified so that axle was moved even further rear than originally! Must have been used in some really tight corners. I also removed all the original front lifter stuff that was attached to the support part.
I can shoot you some pics if needed, just throw me a mail tomi.heinonen(at)konecranes dot com
BR, Tomi
TomppaHe
Maskin: Hako D522
JohnOlof
#113 » 20:57:33, 12-10-2016
jeng skrev:TomppaHe:
Regards jonas
Now I got interested. It doesn't happen to be a loader like mine? I've been thinking about adding a tilt cylinder. Could you show some photos?
JohnOlof
PappaNille
#114 » 23:55:22, 10-11-2016
ang Biltema ATV snökedjor som du tipsade om så monterade jag sådana på min traktor igår.Fungerade klockrent! Monterade även dessa på Kubotan som vi har på jobbet, har kört 4 timmar med den sen dess utan problem och kedjorna ser knappt använda ut trots asfalt/snö/is underlag. BildBild
PappaNille
Maskin: Stiga garden compact -06 -såld
Klippo pro 21- såld
Stiga Park President 14 -2011-såld
Husqvarna YTH184t -såld
Belos 272-såld
Belos 252 -såld
Meek Jordfräs -såld
Ryoby 4t trimmer/slyröjare -såld
Stiga park pro 20 -03 -såld
Kellfri ATV grävare -såld
Simplicity Legacy trädgårdstraktor med lastare
Husqvarna Rider 13 RS
Bobcat X316 minigrävare
Komatsu PC16 minigrävare
JohnOlof
#115 » 00:02:07, 11-11-2016
Roligt när ens erfarenheter kan komma till nytta :thummar:
Borde snart vara dags för mig att putsa lite på lillen och få ut den och ploga.
JohnOlof
jeng
#116 » 10:39:59, 25-01-2017
@JohnOlof:
Här är lite bilder på tiltombyggnad, bättre sent än aldrig! Traktorn är den Hako som finns i början av tråden, men nu med ny ägare..
Så här såg den ut innan, med ryckskopa. Ryckskopan funkade, men var omständig och det var svårt att göra något vettigt med den. T ex skotta uppfarten med singel var omöjligt, antingen ingen snö i skopan eller snö och massor med grus, finjusterings möjligheter med en tiltcylinder behövdes:
jeng
Hakotrac D522
jeng
#117 » 10:51:45, 25-01-2017
Hydraulinstallationen på traktorn var intressant - det är vattenledningar som är lödda med en skruvkran för trepunkten och en för lastaren och sedan får man använda ventilen till vänster om ratten.
Så ett trespaksventilpaket inhandlades på ebay och en tiltkolv hittades på en skrot i Delsbo (Gök-Olles bakom forngården, f ö ett besöksmål som rekommenderas för alla skrotentusiaster! Skrotade maskiner och delar så långt ögat räcker! Så när a en verklig Skortnisse man kan komma)
Här får ni även se min verkstad - uppfarten... För att få plats med tiltcylindern flyttades den under tvärbalken upp till knäcken på lastaren, och den nya undre tvärbalken sågades isär så tiltcylindern kunde röra sig fritt. sedan satte jag vinkeljärn i övre och under tvärbalkarna som tiltkolven sedan sattes fast i.
Lederna gjorde jag av ett u-järn och rörstumpar som lager, funkar väldigt bra.
jeng
Hakotrac D522
jeng
#118 » 10:56:04, 25-01-2017
lite fler bilder:
Satte även på en till ljuddämpare som är riktad uppåt - ganska mycket mindre avgaser i ansiktet när man kör! Dessutom betydligt lägte ljud. Kan även nämna att jag kör på ren HVO-diesel - så fossilfritt man kan komma och eftersom den är syntetisk, betydligt fräschare avgaser!
Så här blev det med skopa och ventilpaket monterat:
jeng
Hakotrac D522
jeng
#119 » 10:58:12, 25-01-2017
Dock var ju skopan i största laget, så jag byggde en ny med stor hjälp av en kollega på jobbet. Om den gamla var för stor, så blev den nya kanske lite väl liten, men fylld med grus är även den i tyngsta laget för den här lilla traktorn..
jeng
Hakotrac D522
jeng
#120 » 11:06:53, 25-01-2017
Så hur har det funkat?
Det första eldprovet var att köra makadam till ett växthusbygge i en slänt - det innebar att traktorn skulle köra upp för en liten men ganska brant backe och det trodde (hoppades) jag hakon skulle fixa - men med grus i skopan slirade den en meter upp i backen så det var inte att tänka på. En minidumper fick inhyras med kort varsel och då gick det som smort.
Tiltfunktionen har fungerat bra, den är snabb, men för svag. Med last i skopan går det inte att tilta upp i skopan. Det är ju ett lågtryckssystem med 40 bar, så tiltkolven på 4 cm är för liten. Jag har köpt en ny kolv med 6 cm, men för att få dit den måste så klart infästningarna byggas om och det har jag inte fått till än.
Ett annat övergripande problem är att den är för lätt i bakändan - trots 2 gamla frontvikter och hjulvikter, summa 110 kg. Så nästa steg är vattenfyllda bakdäck som visats tidigare i tråden. Det borde göra susen.
Andra projekt på gång är att fixa trepunktslyften och snygga upp traktorn lite, men det är så mycket som ska göras så när det blir få vi se!
jeng
Hakotrac D522
Användare som besöker denna kategori: varta och 9 gäster
