Övre skruvarna:
M6 20mm
Den nedre:
M5 15mm
Har inte skaffat ngt än att låsa gängorna med. Har hård Loctite hemma, men den släpper ju av värme...
https://www.aliexpress.com/item/3281927 ... 5ab6178f17
Top Quality! Muffler/Silencer Assembly for MZ175/166F 04 Stroke Gasoline Engine,EF2600 Generator Parts
Model Number: MZ175/166F/EF2600
US $29.90
Shipping: US $33.81 to Sweden via EMS
Estimated Delivery: 14-26 Days
http://echo-usa.custhelp.com/app/answer ... /related/1
https://www.echo-usa.com/Support-Help/T ... 00&c=en-us
PB-4600 - Product Information
Answer ID 804 | Published 02/20/2008 10:14 AM | Updated 09/12/2018 03:40 PM
Manuals:
To download a free copy of the Operator's, Part's and/or Safety Manuals, please Click Here
Accessories:
Part #PBAV-4600 - Vacuum Attachment - Turns the blower into a yard vacuum which bags debris. Vacuum works on re-direction of airflow. Designed for picking up light debris. (Discontinued)
Part #99944100215 - Vacuum Bag - Replacement vacuum bag for vacuum attachment. (Discontinued)
Part #900500 - Static Protection Kit - Eliminates build up of static electricity when operated in dry, dusty areas. Kit includes all necessary hardware to adapt to the ECHO Backpack Blower.
Part #99944100030 - Shoulder Strap - Helps support weight of blower across the users shoulders. (Discontinued)
Part #99944100010 - Rain Gutter Cleaning Kit - Designed to blow the leaves out of the gutters on a single story home. Kit includes all necessary hardware required for installtion. Tubes are 7 feet long when fully assembled. When kit is assembled onto the unit, the user can reach between 13-15 feet.
Part #001107 - Blower Tube Handle Kit - Comes standard with unit. Handle attaches to blower tubes to provide better control.
Part #99944100020 - Blower Tube Loop Handle - Handle attaches to blower tubes to provide better control. (Discontinued)
To view additional accessories such as Personal Protection, Glasses, Gloves, Fuel, Oil and Lube, please Click Here
Re-Power Kits:
Tune-Up Kit: Part #90067 (S/N 059919 & Up, Type 1E) - Includes Air Filter, Fuel Filter and Spark Plug (Discontinued)
Specifications:
Length: 320cm/12.6 in.
Width: 460 cm/18.1 in.
Height: 440 cm/17.3 in.
Dry weight: 10 kg/22 lbs.
Engine Type: Piston-ported, Air cooled, two-stroke, single cylinder gasoline engine
Engine Displacement: 44 cc/2.69 cu. in.
Fuel: Mixed (Gasoline and Two-Stroke Oil)
Fuel/Oil Ratio: 50:1 Power Blend XTM or ECHO Red Armor® ISO-L-EGD (ISO/CD 13738) and J.A.S.O. M345- FD, two-stroke, air cooled engine oil
Fuel Tank Capacity: 1.9 lit./64.3 US fl. oz.
Maximum Air Speed with pipes (MPH): 180 MPH
Air Volume at housing (CFM): 740 CFM
Air Volume at pipes (CFM): 370 CFM
dB(A) Rating: 70
Technical Information:
Manufacture Date: 1992-1996
Short Block: Part #SB1012
Bore: 40.00 mm/1.574 in.
Stroke: 35.0 mm/1.378 in.
Exhaust: Spark arrestor muffler
Carburetor: ZAMA diaphragm type with primer bulb
Spark Plug: NGK BPM-7A or 7Y
Spark Plug Gap: 6 mm - 8 mm/0.24 - 0.26 in.
Ignition System: Flywheel magneto, CDI system
Starter System: Recoil starter
Idle Speed: 2,500-2,800 RPM
Wide Open Throttle Speed (W.O.T.): 6,400-6,600 RPM
1 14580008260 1 MUFFLER ASSY CONJUNTO DE SILENCIADOR
2 + 14551006210 1 GASKET, EXHAUST(1) JUNTA, ESCAPE(1)
3 + 14581008260 1 MUFFLER SILENCIADOR
4 + 14586206720 1 SCREEN, SPARK ARRESTER PANTALLA, SUPRESOR DE CHISPAS
5 + 14586604261 1 GASKET, EXHAUST(1) JUNTA, ESCAPE(1)
6 + 14587408261 1 GUIDE, EXHAUST GUÍA, ESCAPE
7 + 90023804010 5 SCREW - 4X10 TORNILLO - 4X10
8 90010506020 2 SCREW - 6X20 TORNILLO - 6X20
9 90016205020 1 SCREW - 5X20 TORNILLO - 5X20
10 10157608260 1 COVER, CYLINDER CUBIERTA, CILINDRO
11 14551006210 1 GASKET, EXHAUST(1) JUNTA, ESCAPE(1)
(FOOTNOTE) 1 - Included In GASKET KIT (NOTA DEL PIE) 1 - Incluido en KIT de la JUNTA
- 7 -
PB-4600 TYPE 1 POWER BLOWER
Soplador de Mochila Exhaust Escape
