ForumindexMaskinforumJordbruksmaskiner och -redskapPlogar
Kverneland Le-9: söker broschyr eller manual
7 inlägg • Sida 1 av 1
Diskutera plogar i detta forum
Holger (trådstartaren)
#1 » 19:19:50, 16-11-2011
Våra vänner i Bosnien söker:
Kverneland Le-9 reversible plough built in 1988. He really needs some brochure or setup manual
http://www.maskinisten.net/viewtopic.ph ... 154#318154
Någon som kan hjälpa dem?
Holger
Webmaster
Webmaster
Maskin: Test
selmir_Bosnia
#2 » 19:28:18, 16-11-2011
Thank you Holger!
Here you can see some pictures of that plow:
If anyone have any brochure or manual or anything, please help!
selmir_Bosnia
Ort: Bosnia and Hercegovina, Ugljevik 76330 Janjari bb
Maskin: IMT 539
Zetor 7045
Hako Hakorette+ACME 8HP engine
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#3 » 19:29:57, 16-11-2011
Are you sure about the model? I cannot find anything on the net about it!
Holger
Webmaster
Webmaster
Maskin: Test
Bengt Erik Eriksson
#4 » 00:52:25, 17-11-2011
Hi i found a broshure from 1988 wich tells about a "LD" model with the same turninghead as yours(120) and shearbolt stone protection wich i guess the "L" stand for. see picture. unfortunately there was no picture of the plow. I guess your "e" and this "D" stands for different "body distance" this says 85 cm (along frame)
the list specifies weight and required lift capacity and model of turninghead
The text tells its a cost efficient model for farms with very little amount of rocks in soil. and that it have 85 cm body distance.
adjustable furrow width.
I got no instruction to this. but i have exploded wiews of several bodies with part numbers. can you tell wich one you have or just a part nr and i propably can find it out..
edit: maybe "e" stands for fixed furrow width?
I grew upp 9 Km from Överum (swedish plow maker) so i´m not a kverneland expert...
Bengt Erik Eriksson
Maskin: AVANT 218 -11
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
kiraj
#5 » 15:59:27, 17-11-2011
.The brochure for the plug to me.
Originalets URL: http://img803.imageshack.us/img803/9185/kverneland.jpg
Originalets URL: http://img703.imageshack.us/img703/2820/image00001xl.jpg
Originalets URL: http://img406.imageshack.us/img406/4012/image00002qv.jpg
Originalets URL: http://img205.imageshack.us/img205/2761/image00005x.jpg
kiraj
Bengt Erik Eriksson
#6 » 17:56:07, 17-11-2011
I can scan the whole broshure if you want but it contains no adjusting information and copied text is the only one to read about any similar plow as yours.
In this link the adjustments for "överum " plows is described. Im aware it is not your plow. but te ideas for adjustment an preparing of tractor is principaly the same as the "CX" model desribed. Choose language first and download.
http://www.kongskilde.com/Soil/DbBrands ... ductid=281
I will continue searching info but i sugest this so far..
BTW it seems kverneland is not as helpfull with online stuf..
Here is your first picture added with basic comments if you don´t mind.
Bengt Erik Eriksson
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
Matte.Hartman
#7 » 18:31:13, 17-11-2011
Don´t really know anything about plows but could this be useful? It´s even in english. :)
Don´t know which years it covers but i hope it may be to some help. :) Sent the file to the downloads section to.
Kverneland - ED-FR LD-FR Operating manual
Edit: Link to some Kverneland manuals
Matte.Hartman
Maskin: Volvo BM 2250 -81
Volvo BM T430 -77
Polaris Sportsman 500 -05
Polaris RMK800 -00 (Till salu)
SkiDoo Alpine 503 -83
SkiDoo MXZ670 -97 (Till salu)
Återgå till Plogar
