Instruktionsbok Aktiv slåtterbalk
20 inlägg • Sida 2 av 2
Diskutera vallmaskiner här
SethDZeigler
#16 » 08:27:05, 26-06-2015
Two of the guards are of a different type and seem ok, they are cast with A874B on them...
SethDZeigler
Maskin: Nokota Hästar och Massey Ferguson 135
SethDZeigler
#17 » 09:42:14, 26-06-2015
And the plot thickens... i started to dismantle, and that gives some more information. i guess that the metal plate which holds down the plate at the attached end of the knife is a form of adjustment, and under it was a stack of 9 shims! 9 seems exceptional, like a former attempt at some sort of correction, and clearly would elevate the points of the knives substantially relative to the bar itself. So i am definitely thinking i need to remove some of them, and wondering ever more what the history of this machine was... is an Aktiv Sprinter more of a light duty machine or something that does stand up to the test of time and wear? :klia:
SethDZeigler
SethDZeigler
#18 » 09:45:07, 26-06-2015
oh, and that first serated guard nearest to furthest to the head is one of the two that were not so buggered up...
SethDZeigler
Andreas.karlsson
#19 » 16:45:04, 30-09-2021
SethDZeigler skrev:Bild
De 2 plattjärnen som sitter mellan vevstake och kniv, är det Rätt att rundningen ska vara Uppåt som enligt bild?
Andreas.karlsson
Maskin: John Deere 1120
Reijmyre
#20 » 23:40:20, 31-07-2022
Slåtteraggregat Westeråsmaskiner F
Hej alla, jag söker fästanordning (bult, fjäder, hållbricka och mutter) för vingens fastsättning på fingerbalken. Kan någon ge mig tips om var man kan hitta dessa reservdelar? Vet tyvärr inte årsmodell.
Reijmyre
1 inlägg
Återgå till Vallmaskiner
