ForumindexMaskinforumBil/MCMC
LED strålkastare. LED stålkastarinsats
4 inlägg • Sida 1 av 1
Snacka om MC här
dc_lindberg (trådstartaren)
#1 » 20:18:44, 16-02-2020
http://www.louis.eu säljer några olika LED strålkastare, monteringsbara på MC.
https://www.louis.eu/artikel/truck-lite ... r=10035484
Truck-Lite LED Headlight Unit
One of the brightest bi-LED reflector headlights around, which redefines vision and visibility. The powerful illumination is close to daylight and therefore considerably easier on the eyes, while the extra brightness makes night-time riding much less of a strain. Lower current requirement means less drain on the alternator, thus reducing consumption.
Low beam, high beam and parking light
◾12 V 31/18 W
◾Dimensions: Dia. approx. 177 mm, depth approx. 97 mm
◾Fits in many 7-inch (PAR56) headlight housings
◾Sturdy, coated polycarbonate lens
◾Die-cast aluminium housing conforms to US military standards
◾Metallized reflector for clear, sharp illumination
◾Encapsulated electronics protect against corrosion and vibration (important for vehicles that are subject to powerful vibrations)
◾H4 connector
◾E-approved
Due to the illumination which is developed for right-hand traffic, it is not recommended to use this headlight in left-hand traffic.
Please note that the LED headlamps heat more than a H4 headlight unit. Proper ventilation must be provided. Cables should not be placed in the lamp housing.
Tyvärr vägrar Louis att besvara frågan:
- "är lampan laglig att användas på väg?" (street legal)....
https://www.louis.eu/artikel/adaptive-l ... 89e70d0986
Adaptive LED-Headlight insert
5 3/4'' from JW SPEAKER
Seeing and being seen can be a matter of life or death for motorcycle riders. Enormous progress has been made in this area thanks to modern LED light technology. The adaptive headlight from JW Speaker takes vehicle lighting to the next level. This LED headlight gives your motorcycle a highly effective cornering light, so you have a better view into bends. And it's easy to fit in place of you normal headlight!
The adaptive headlight from JW Speaker is equipped with special position sensors, which measure your bike's lean angle in corners and switch on additional LEDs to illuminate the inside of the bend. That means better illumination of both left and right curves, in contrast with conventional headlights. Adaptive 2 Headlights with "dual burn" function, i.e. the low beam stays on when you switch on the high beam. ECE-approved.
Details: JW Speaker Model 8690/Adaptive 2
◾ Round headlight
◾ Fits in many 5 3/4-inch headlight housings
◾ Powerful low beam with 1,020 eff. lm / 8,300 cd
◾ High beam with ComfortLite 1,600 eff. lm / 60,000 cd
◾ ECE street-legal (Reg. 113)
◾ Housing made of heavy-duty, corrosion-resistant aluminium
◾Adaptive 2 headlights: With "dual burn" function
◾A position light is included.
Also available as 7" headlight - see "Compatible products".
Please note that the LED headlight unit becomes hotter than an H4 headlight unit. Adequate ventilation must be ensured. Do not place cables inside the headlight housing.
...kan det vara så att den inte är laglig... den är ju så mkt billigare än det andra exemplet... :klia:
Någon som provat någon av Louis LED huvudstrålkastare?
Att HD har, men BMW har inte...
dc_lindberg
ons 02 mar 2005, 23:06
Senaste besöket:
mån 10 apr 2006, 13:31
Senaste besöket:
tor 13 apr 2006, 17:08
tis 14 aug 2007, 09:57
Senaste besöket:
mån 10 dec 2007, 14:11
#2 » 21:33:11, 16-02-2020
Tittar man på bilderna så har de ett E-märke med en siffra. Jag har inte kollar vad de siffrorna står för.
Den dyrare sorten verka ha ett inbyggt kurvljus om jag har förstått det rätt.
MF 30 med Bergsjö 108 lastare
I-H 574 -74
MF 175 -72 med Modig lastare
Terri 1020D -84/87
Fiat 680DTH -79 med Veto FX15
#3 » 03:24:39, 17-02-2020
E-godkänt = kravet för att få användas inom EU
ECE godkänt = lagligt att använda på allmän väg
Trafikverket = :cencored: , tror sig kunna sätta sig över EU-lagen... det är Förordning 48 som gäller, inte Trafikverkets hopkok till fri översättning och egensinniga tolkningar (=påhitt)!
Tror att det är här som Louis inte fattar skillnaden mellan E-GK och ECE-GK...
8-10 lakan lägger jag inte! Men ett par kan jag sträcka mig till.
Visst kan man montera o tjafsa med "vänner av ordning"; men står det ECE... :djaevul: då har de bra att hålla tand för tunga! :skratta3:
dc_lindberg
Senaste besöket:
Senaste besöket:
Senaste besöket:
#4 » 07:54:56, 17-02-2020
Nja, E-märket är "beviset" på att en produkt är provad av en myndighet enligt ett eller flera ECE-reglementen. Det har inget att göra med EU. E-märkningen och ECE-reglementena har funnits sedan 1958 , det är FN som ligger bakom regelverket och det tillämpas även i många länder utanför EU (större delen av världen utom USA).
En produkt som t ex en strålkastare kan ju vara provad enligt flera olika ECE-reglementen, och den kan mycket väl ha ett E-märke utan att vara lämplig eller tillåten för en viss specifik tillämpning. T ex finns det ju E-märkta strålkastare med vänsterasymmetriskt halvljus, avsedda för länder med vänstertrafik, de får inte användas i högertrafikländer. Och det finns många ECE-reglementen för olika slags strålkastare, som ändå inte är tillåtna att användas på exempelvis personbil eller MC.
Återgå till MC
