Hoppsan - den här var det; Julas måste sålt ngr olika:
https://www.mydeal.com.au/yukon-15-ton- ... ter-in-red 15Tons of splitting force
196cc Commercial-grade motor
Hydraulic pressure: 21Mpa
Solid Steel Frame
Hydraulic
Seal system minimises risks of leaks
Solid steel forged splitting head
Superior
oil filtration means low maintenance
Oversize 70mm hydraulic cylinder
10-inch wheels for easy portability
AUS/NZ-standard dual redundancy safety
Dimensions: L144 x W69 x H55cm
https://fellotool.eu/product/petrol-log ... t-hls10tg/€739.00
0 review | Write a review
Fellotool HLS10TG Powerful Horizontal 10 ton petrol Log Splitter
Contact us to order this product
Send to a friend
SKU: 60015 Category: Electric and gasoline engine log splitters
Specification
Slice tough Logs with Ease Using Our Horizontal 10 ton petrol Log Splitter
Gasoline 10 ton log splitter is powered by a 6.5-horsepower, 196-cc engine with CE approval.
2-hand safe
control;
Two-speed
valve with quick speed for moving quickly and a slow speed when required.
Reliable pump and valve delivers efficient splitting production;
The big wheels measure 12 inches for easy moving;
Hi-pressure hoses are wrapped in nylon sleeves;
Log catcher / wood-plate is optional;
Cross wedge is optional;
Engine Power Output: 6.5HP/196cc
Speed: 3,600 RPM
Splitting Force:10 ton
Oil Tank: 3.5L
Log Splitting Capacity: 520mm
Log Diameter: 70-350mm
Stroke forward speed: 11 seconds
Stroke return speed: 8 seconds;
Snarlik:
https://sinoplant.co.za/products/log-sp ... ol-15-ton/Jag kan varmt rekommendera den lösningen.
196cc 6.5hk topventilsmotorn drar överraskande lite
bränsle!
Rekommenderar dock... att man använder Aspen och inte 95-oktan... mina kläder stinker å hur lungorna mår blundar vi för.
