BÖHLER FOX CEL verkar vara en 6010 elektrod, om det säger någon nåt:
http://www.svenskaelektrod.se/svets/boh ... er-fox-cel
ja-bond77 skrev:Jo... Men kanske Filarc 35 skulle vara ändå bättre? Den borde väl ha samma hållfasthet som 48.00 men tycker själv den är lite lättare att svetsa med. Och högutbyteselektrod dessutom så det bygger på bra... 48:orna tillför väl inget till fogen från höljet?
ja-bond77 skrev:Du menar det är samma hölje på 35 och 48?
There are 4 groups of electrodes:
1. Fast Freeze
2. Fast Fill
3. Fill Freeze
4. Low Hydrogen
6010 and 6011 are in the Fast Freeze group. This is great for general purpose welding. They have deep penetration, and can work well on dirty or not-new metal, making them great for repair work. The Fast Freeze nature allows them to be used to fill wide gaps well, making them ideal for doing root passes. 6010 is DC only and 6011 can be used on AC or DC. These rods can be used in any position.
Most hobby guys won't use anything in the Fast Fill Group, example would be a 7024. This is super high deposition electrode that can used only in the flat and horizontal positions, uses an assload of amps, and is really only used on really thick steel.
Fill Freeze is kind of the weird odd-ball group. 6013 is in this category. I still maintain 6013 is fucking useless. I'm not familiar with any other electrodes in this group. Perhaps other people have experiences with this category they can share. I've yet to talk to anyone who does.
Low Hydrogen. this is where your 7018 lives. It's a medium deposition electrode that deposits more metal faster then your fast freeze electrodes but not as much as your fast fill. Good luck filling up gaps with any finesse, working on thin steel, dirty metal, or making lots of tack welds. It makes beautiful strong welds on well fitted and clean steel fabrications. Works in all positions and mainly for DC. They have an AC version of 7018 but I never got it to work on my equipment.
So long story short for a well rounded welding shop you need electrodes from the Fast Freeze Group and the Low Hydrogen group. Whatever classification system your region uses, they will still fit under these 4 groups.
ja-bond77 skrev:Jo det verkar väl rimligt... Eller... Kan man se det i några förteckningar? Oberoende så är det väl "eldmaterialet" som avgör hur man upplever svetsegenskaperna. Bara mittråden bränner ju oftast fast ögonaböj utan höljets tillförda egenskaper i brasan. Därför tycker jag det är märkligt med uttalanden som att "här ska det svetsas 7018", eller 6010, eller nåt annat. Som TS nämnde... Proffsen klarar väl rätt bra att svetsa med vilken exv 7018 elektrod som helst(beroende på läge mm) utan större bekymmer men för oss glada amatörer är det tydlig skillnad mellan de enskilda elektrodvarianterna av 7018.
Bengt Erik Eriksson skrev:Hm vad motsvarar då 6013 som man ska akta sig så noga för?
