Volvo L70B/C Svetsa gjutjärnet i motvikten
29 inlägg • Sida 2 av 2
Diskutera svetsning här
#16 » 20:00:49, 27-05-2016
I think you should listen to all advises already left.
Find som high nickel filler rod and preheat if possible the give it a shot. Also grind and clean cracks if possible.
There should be possible to find a used one too, at least in sweden. How much will it cost to ship that?
jinf (trådstartaren)
#17 » 20:07:31, 27-05-2016
magloman skrev:I think you should listen to all advises already left.
All advice is very apprcaited,
What is the price of used one in Sweden? " C series is the same"....
What you mean in High nickel rod? "High quality"
jinf
International
Norpan
#18 » 20:39:46, 27-05-2016
A weld rod made of mostly nickel, it is what usually is used to weld cast iron.
Norpan
G-son
#19 » 20:41:07, 27-05-2016
Welding rod for cast iron usually contains alot of nickel = high nickel rod.
However, if it's cast steel it should (as far as I know) weld fine with rods for ordinary mild steel. So, as I said, first figure out what it is, THEN start planning for how to weld it.
G-son
#20 » 20:43:04, 27-05-2016
Norpan skrev:A weld rod made of mostly nickel, it is what usually is used to weld cast iron.
Thank you for advice,
jinf
International
#21 » 20:45:09, 27-05-2016
G-son skrev:Welding rod for cast iron usually contains alot of nickel = high nickel rod.
Is clear,thank you for advice is very appreciated,
jinf
International
PerJohansson
#22 » 20:48:16, 27-05-2016
I would with high certainty say that it is gray cast iron. Why make anything out of a more expensive material if there is no need?
Anyway, if i remember it right, grinding steel makes yellow straight shooting sparks and grinding cast iron makes white sparks with a more diverse pattern. To be sure you can grind on some parts that you know is steel and cast iron and compare the sparks.
PerJohansson
Maskin: Ferguson TEA 20
Ursus 385 De Luxe -80
SL55
#23 » 20:56:08, 27-05-2016
PerJohansson skrev:I would with high certainty say that it is gray cast iron. Why make anything out of a more expensive material if there is no need?
Very logical experiment,I appreciate your experience....
jinf
International
G-son
#24 » 21:04:30, 27-05-2016
G-son
#25 » 21:07:42, 27-05-2016
G-son skrev:http://value-of-silver.blogspot.se/2012/11/the-spark-test-and-spark-testing-metals.html
Good reference,and valuable information,
jinf
International
#26 » 10:46:35, 28-05-2016
Contact swecon in sweden, they have their own demolition facility/ scrapyard for used construction machines. To find out price on used but whole counterweight.
#27 » 10:59:47, 28-05-2016
magloman skrev:Contact swecon in sweden, they have their own demolition facility/ scrapyard for used construction machines. To find out price on used but whole counterweight.
If you have contact detail,for specific person please send via PM,
As you know swecon,is very large wide company....
jinf
International
ianews
#28 » 15:20:14, 28-05-2016
You will have to demount the weight first. Grind out an extremely large V around the crack. Weld with any cast-iron electrode: OK 92.18 for example. Pre-heat 150-300 degrees centigrade and weld away. You usually weld small amounts and hammer the weld but I think as there is no strain I would weld as normal. However this is an extremely expensive method. Cast iron rods cost a fortune. As previously mentioned bolt it together. It works and will be much cheaper. Drill holes and tap the holes for 3/4" thread for example. Bolt together with 12mm steel.
IanM
ianews
Blogg: Visa blogg (1)
Maskin: Gammal JCB traktorgrävare från '86(?). TIG, MMA och MIG/MAG, Blomqvist svarv.
#29 » 16:09:40, 28-05-2016
ianews skrev:You will have to demount the weight first. Grind out an extremely large V around the crack. Weld with any cast-iron electrode: OK 92.18 for example. Pre-heat 150-300 degrees centigrade and weld away. You usually weld small amounts and hammer the weld but I think as there is no strain I would weld as normal. However this is an extremely expensive method. Cast iron rods cost a fortune. As previously mentioned bolt it together. It works and will be much cheaper. Drill holes and tap the holes for 3/4" thread for example. Bolt together with 12mm steel.
Thank you very much for useful advice,your experience is very valuable,
jinf
International
Återgå till Svetsning
