ForumindexDiverseBild-serier och filmsnuttar
Fixar en trasig Hitachi som varit i skogen i många år mm maskiner
11 inlägg • Sida 1 av 1
Här kan du starta inlägg med bild-serier på maskiner.
Använd detta forum även för roliga filmsnuttar som du hittar på nätet.
Pitepelle (trådstartaren)
#1 » 19:49:01, 03-01-2021
Abandoned Excavator left in woods for 16 years- Will it start ??
https://www.youtube.com/watch?v=sFudJ2yIBJE
Abandoned digger gets some much needed maintenance- Thanks Supercheap Auto
https://www.youtube.com/watch?v=eeKdVb-Folg
Fixing a leaking Hydraulic Arm Cylinder on the Abandoned Excavator
https://www.youtube.com/watch?v=0rd5jNLoTaE
Excavator driver Attacked by Angry Wasps after disturbing a nest
https://www.youtube.com/watch?v=QRBU5-P ... gA&index=2
Abandoned digger gets new bucket/hitch pins and widens a narrow trail
https://www.youtube.com/watch?v=LfDDtOdcLlQ
Abandoned digger and Vintage Bristol Bulldozer widening corners on a steep track
https://www.youtube.com/watch?v=JZ385uGHejc
Pitepelle
Maskin: Volvo BM 4200B 1984
Liebherr L507 2007
#2 » 19:54:18, 03-01-2021
Han fixar även en bandtraktor ur skogen
Caterpillar D2 Bulldozer broke down in a forest 13 years ago. Can we save it?
https://www.youtube.com/watch?v=5hEKmECUFeE
Rescued Cat D2 goes back to work- Cutting a track through gorse
https://www.youtube.com/watch?v=_5GjlAY ... gA&index=5
Rescued Vintage Cat D2 Bulldozer clearing a firebreak
https://www.youtube.com/watch?v=TaiG8cQ ... gA&index=6
Abandoned Caterpillar D2 dozer part 3 - Reassembling the engine, Will it start?
Volvo USA Visar specialmaskiner
Vintage Bulldozer forgotten for a decade.. Will it start??
https://www.youtube.com/watch?v=9kU-a0PtOD8
Vintage Bristol Dozer repair part 1
https://www.youtube.com/watch?v=OaFCq-K4X-c
Vintage Bristol Dozer repair part 2- changing fluids/filters and pushing some dirt
https://www.youtube.com/watch?v=_AYR61q5zPE
Pitepelle
Liebherr L507 2007
#3 » 20:14:01, 03-01-2021
Rep av väghyvel
https://www.youtube.com/watch?v=vrffgwd ... mb_rel_end
12 Ton Grader for scrap value. Part 2 - How bad is it?
https://www.youtube.com/watch?v=LqIx_Co ... gA&index=2
12 Ton Grader for Scrap value Part 3- Long Overdue Repairs & Maintenance
https://www.youtube.com/watch?v=6Quj6-TXjYc
12 Ton Grader part 4- Replacing the broken drive-chain and back to work.
https://www.youtube.com/watch?v=vrffgwd ... gA&index=1
Pitepelle
Liebherr L507 2007
#4 » 20:41:22, 03-01-2021
Rusty old Tractor with grader blade for $500 - Lets fix it.
https://www.youtube.com/watch?v=eVvO1tKKjRQ
$500 David Brown Tractor gets a service, then back to work grading a 4 mile driveway
https://www.youtube.com/watch?v=0fwG2KUPeGI
Fixing a Wobbly tractor wheel on the $500 David Brown 990
https://www.youtube.com/watch?v=bE2284DZiPc
Pitepelle
Liebherr L507 2007
#5 » 22:49:51, 03-01-2021
Homemade Backhoe and $500 David Brown Tractor clearing a culvert
https://www.youtube.com/watch?v=m3LnFAe0HTM
Pitepelle
Liebherr L507 2007
#6 » 23:17:44, 21-06-2021
Fixar till en Fiat Allis 645B som inte varit i gång på flera år
https://www.youtube.com/watch?v=jbyv7vYYiNQ
Pitepelle
Liebherr L507 2007
#7 » 23:30:35, 21-06-2021
Fixar i gång en bandtraktor som inte varit i gång på flera år
Caterpillar 977k
https://www.youtube.com/watch?v=5et2i2aIpcM
Pitepelle
Liebherr L507 2007
#8 » 22:49:17, 22-06-2021
Repairing & steam cleaning 20+ years of Filth off of Abandoned Clark wheel Loader
https://www.youtube.com/watch?v=-EG6uYfuGQM
Nu ska man göra väg med maskinen
Film 2
https://www.youtube.com/watch?v=WzdbnxrJuhM
Pitepelle
Liebherr L507 2007
#9 » 20:11:43, 15-01-2022
Pitepelle
Liebherr L507 2007
Iznogoud
#10 » 20:15:25, 15-01-2022
Varför inte lägga in youtubelänkarna direkt i inlägget via [youtube][/youtube] knappen i verktygsfältet ovanför textfältet?
Generation G :hotar2:
Iznogoud
Maskin: Ford 2600 -76
Volvo LM 621 -72?
Jonsered LT2313 -19
rospigg
#11 » 22:19:26, 15-01-2022
Och jag som trodde att det var en projekttråd. :sad:
rospigg
Maskin: BM 36-57
Volvo t25 med perkins 4.107
MF 356 "rullstol"
BM 640 -69
Återgå till Bild-serier och filmsnuttar
