ForumindexMaskinforumThe Hymac ClubHymac Technology
Renovating an old Hymac 580BT
20 inlägg • Sida 2 av 2
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
Kenneth Frydenlund (trådstartaren)
#16 » 09:28:02, 07-06-2010
She’s finally out and about! :dancing_geek:
Note the ergonomically correct operator position. :cool:
Kenneth Frydenlund
Norge
Maskin: Zetor 8540, MF 35, Hymac 580BT, Hinowa DM-40L
Holger
#17 » 11:56:10, 07-06-2010
Wow! What a beauty! :grin:
Holger
Webmaster
Webmaster
Maskin: Test
Jeremy Rowland
#18 » 22:27:31, 07-06-2010
Wow another fine restoration, top job there :buga: :thummar:
Jeremy
Jeremy Rowland
International
David.Mattsson
#19 » 23:33:48, 08-06-2010
to bad i dont drive semitrailer annymor other wise i wold paid you a visit
Keep ut the god work ! :cool2:
Jag vet varför engelsmän dricker varm öl
David.Mattsson
Maskin: JCB
#20 » 19:35:35, 01-08-2010
Hi all,
Here's another quick update.
Have finally finished the electrics, and now the engine starts the way it should. So far it seems to be running smoothly. Have also replaced the wires for the throttle control and engine cut-off. Now I can even shut her down without having to climb back to the engine to shut her down.
The old ignition key assembly was damaged by water and corrotion, so rather than replacing it with a new original one, I have replaced it with a keyless switch.
Have used her a little bit this weekend, and have to say I'm surprised how strong she is. Even the tracks seems to run smoothly.
Can't wait to put her to work on a real project.
Things remaining to do:
- Mount the door for the cab (just finished painting it, still have to mount the windows in the door)
- Mount the seat
- Mount front window
- Mount air filter (missing hose from engine to airfilter)
Kenneth Frydenlund
Norge
Återgå till Hymac Technology
