ForumindexMaskinforumThe Hymac ClubHymac Technology
Hymac 580C Restoration
60 inlägg • Sida 4 av 4
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
David.Mattsson (trådstartaren)
#46 » 07:20:42, 04-08-2010
just need some houers in it to get the flow in the digging :)
Jag vet varför engelsmän dricker varm öl
David.Mattsson
Maskin: JCB
#47 » 17:36:08, 03-03-2011
Today i have moved her to another farm ther i will clean ditches
som pictures of her on the SCANIA
it was quite hevvy
David.Mattsson
Maskin: JCB
Jeremy Rowland
#48 » 23:40:59, 03-03-2011
Nice pics David thanks for sharing them :thummar: the 580C does weigh in at 12 tons and being as the load is high for that type of truck it would make it feel top heavy as the centre of gravity would be higher!
Jeremy
Jeremy Rowland
International
#49 » 08:20:00, 24-03-2011
HELP!
Annyone that haw an idea or hawe a bigg macine that can help?
Ring om ni vet någon i närheten av ryd som kan lösa detta !
0708964440
David.Mattsson
Maskin: JCB
Jeremy Rowland
#50 » 21:06:25, 24-03-2011
Hi David,
The best way to recover the machine is to use a winch, try and find a heavy recovery truck that has a winch on the back and chain the truck to something solid like a large tree then winch the machine out.
Thats the way I would recover a machine stuck in that way, hope that helps.
Jeremy
Jeremy Rowland
International
#51 » 21:45:52, 01-04-2011
The macine is recoverd i vill post photos and film of the recovery her soon
we used
JCB fastrac with bigab 10-14
Bobcat 8ton digger
Scania with palfinger 13tm crane
Fendt 310lsa
Lamborghini 850dt with patu forrest cran for loading loggs in the ditch
i hawe started it an driven it upp to the road so i can make som minor repairs.
David.Mattsson
Maskin: JCB
PB71
#52 » 22:12:15, 01-04-2011
Skönt att ha fått upp den ur diket ! :thummar: Hoppas inte det blev några större skador bara ...
Scania V8 det är grejor det ...
PB71
Maskin: Åkerman H25 nr 0022
Case 1150 Bandlastare
Volvo BM 1641
Scania R144 -01
Scania LA82B -61
Scania LBS 141 -78
Jima minigrävare
#53 » 09:20:55, 24-04-2011
The radiator shord (kylarmask) got damaged so i had to cut the belt to the fan to start it but i will start reparing it when im don with the spring .... (Vårbruk)
Her are some picures of the first try of recovery that failed mor pictures to come they ar on a frinds computer
David.Mattsson
Maskin: JCB
Jeremy Rowland
#54 » 10:44:04, 24-04-2011
Great pictures David thanks for posting them and look forward to seeing the rest. :thummar:
Jeremy
Jeremy Rowland
International
olle67
#55 » 10:47:23, 24-04-2011
You should have a tilt-bucket instead off tilting the machine,,, :mrgreen:
olle67
#56 » 08:42:09, 29-08-2011
ok now i hawe the film of the recovery but it is 10 files and 2.4gb so somone might know haow to edit it an wher to post it
David.Mattsson
Maskin: JCB
Jeremy Rowland
#57 » 22:53:57, 29-08-2011
David.Mattsson skrev:ok now i hawe the film of the recovery but it is 10 files and 2.4gb so somone might know haow to edit it an wher to post it
Try Youtube?
Jeremy
Jeremy Rowland
International
#58 » 22:05:25, 31-08-2011
David.Mattsson
Maskin: JCB
Jeremy Rowland
#59 » 22:45:11, 31-08-2011
Looks like plenty of hard work there David very good video :thummar:
Jeremy
Jeremy Rowland
International
Conrod
#60 » 03:08:40, 04-04-2012
:thumme: Very good that it come up out of the hole
Now you don´t need to baptised it i have a name suggestion for you
If you want a name for it just call it " Dino " like all the old dinosaurius that
have went in a hole like that
I will think your machine is strong like a Dino any way
God luck! and many thanks for your pictures you have put in the forum :wave:
Conrod
Maskin: Scania P82H
Återgå till Hymac Technology
