ForumindexMaskinforumThe Hymac ClubHymac Technology
Hymac 580C Restoration
60 inlägg • Sida 2 av 4
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
orwak
#16 » 21:10:40, 29-09-2009
nice machine! only a bit jealous on your nice and fresh crawlers:)
De finns alltid nåt att laga
orwak
David.Mattsson (trådstartaren)
#17 » 10:48:53, 30-09-2009
Do annyone know what material the Idler Wheel Busshings are made of ?
Buy the look off them i wold say som kind off steel ?
what to use ?
I hawe a Svarv to make new once myself.
i haw 8mm of free play in them so i realy need to change
Jag vet varför engelsmän dricker varm öl
David.Mattsson
Maskin: JCB
#18 » 18:55:34, 04-10-2009
Som work done to the Hymac today.
Loading of the idler wheel
After som work i managed to split it
Svarvning off Axel after welding
the wheel i used a fräs to get a new surfuse only new busshings neaded
And some elictrical removed preparing to remove the Cab
David.Mattsson
Maskin: JCB
#19 » 21:55:14, 13-10-2009
Time for som uppdate
When i opend the transmissions level plug i found that they wher owerfilled with hydralic oil so i removed the motors for replacing of the seales i found that most of the o-rings wher dried out and hard som i Whent to Sverull In Växjö and orderd new ones.
On the way taking it apart forgott to take fotos :(
Motor reddy for installation anny whay
Inspecting the Chain... sems ok
and i hawe been out at my frinds Garage and made the bussings for the first idler wheel
and the busshings is in place just neeade to make som "Axial" spacers
i will go down to the scrapyard tomorrow and see what i can find.
David.Mattsson
Maskin: JCB
Nick Drew
#20 » 23:05:15, 13-10-2009
You are doing a great job there David !!
Keep up the good work :grin:
Nick :D
Please check out my blog http://www.earthmoversmagazine.co.uk/?page_id=3092
Join the Digger Man Blog Facebook page, click on this link to apply to become a member https://www.facebook.com/groups/1422908344617046/
Nick Drew
International
Knut.Karlsson
#21 » 08:09:11, 14-10-2009
David.Mattsson skrev:Bild
This hydraulic motor looks almost identical to the hydraulic pump on my Hymas 474. The only difference i can se on this picture is that the pump don´t have a splined shaft.
Nice restoration. As i wrote in another restorationthread, I like threads with lots of pictures from the "inside".
/Knut
Hymas 474 -74 Min första maskin!! Nu är den såld. Ingen maskin längre. :-(
If it works dont f*** with it
If its f****ed blame someone else
If its your fault that its f***ed, say and admit nothing.
Knut.Karlsson
Jeremy Rowland
#22 » 09:51:28, 14-10-2009
Nice job your doing there :thumme: looks like you've plenty to do as well, It will be worth it when its complete keep up the good work.
Good pics too :thummar:
Jeremy
Jeremy Rowland
International
#23 » 18:37:56, 14-10-2009
Thanks for the positive feedback
Today i was at the scrap yard and tock a off topic photo of 2 English classics
a 1984 JCB 4 Cyl Perkins TD and a 1975 Poclain 5 cyl Deutz
The Poclain is used to outload scrap metal with Magnetic "pickup"
Annyway i found the material i neaded for my shims
I will try to mak them tomorrow
Buy the way Can annyone tell if the crawlers is a standard type hawe read somthing about D4... or somthing
i nead to replace a coupel of the spacers they seem to be of a hard material so i think i neead to buy replacements.
David.Mattsson
Maskin: JCB
Jeremy Rowland
#24 » 22:46:42, 19-10-2009
Hi David,
Well the Poclain pic is good but Poclain is a French built machine.
I am not sure of the spacers that you are talking about for your machines undecarriage?
I would think that these parts would be available off the shelf, if not there is no reason why you could not get some locally made and hardened?
Anyway here is a link to your local Hymac dealer who should be able to help you;
http://www.petterssonsweden.se/text1_14.html
Please let us know how you progress.
Jeremy
Jeremy Rowland
International
#25 » 21:21:49, 13-11-2009
a littel off topic but an explanation why nothing happens her right now
At the moment i hawe broken my Left ( Fotledsfraktur) Wrist so it will take aproximatly 8 weeks untill im back :(
i was kiked buy a Highland cattle Bull
I can see the macine from my window bu´t cant do anny work to it right now. tody is the first day i can sitt at the Computer after the surgery
David.Mattsson
Maskin: JCB
Jeremy Rowland
#26 » 23:02:48, 13-11-2009
Hi David,
Sorry to hear about your broken wrist, I also had a badly broken wrist as a teenager, fortunately they did not have to operate on my wrist to set it again.
Get well soon and keep us all updated with the rebuild, best wishes.
Jeremy
Jeremy Rowland
International
Holger
#27 » 10:00:19, 19-11-2009
Get well soon David!
Holger
Webmaster
Webmaster
Maskin: Test
#28 » 15:05:44, 09-02-2010
After 3 mounths and 1 week
i hawe been out trying to work on the hymac but my foot still hurts and the snow is deep so i will hawe to wait.
The first idlerweel is done and the second is off the undercarrige but i hawe to move it to a frinds workhop to split it apart.
at the moment im consentrating on getting the traktor done
best regards David
David.Mattsson
Maskin: JCB
#29 » 19:51:34, 16-03-2010
do annyone know haow this is used ? anny picture
http://www.blocket.se/goteborg/Dolly_ti ... w=3&last=1
David.Mattsson
Maskin: JCB
Kenneth Frydenlund
#30 » 15:38:57, 09-04-2010
I believe this picture can give you an idea as to how it is used.
http://www.maskinisten.net/album_showpa ... ic_id=3315
I have not seen it in use myself, but from the pictures I guess the "claws" at the front of the dolly hooks on top of the undercarriage on the digger, ant the tracks are placed on the plate in front of the dolly wheels.
Kenneth Frydenlund
Norge
Maskin: Zetor 8540, MF 35, Hymac 580BT, Hinowa DM-40L
Återgå till Hymac Technology
