ForumindexMaskinforumThe Hymac ClubHymac Technology
Hymac 580C Restoration
60 inlägg • Sida 3 av 4
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
David.Mattsson (trådstartaren)
#31 » 23:16:27, 10-04-2010
im planing to make an oil chanage on the hydralulik system but what oil is recomended i got new filters from Bathso maskin outside perstorp but dident ask what oil they recomended.
but i hawe found a good price on q8 H46 oil
thing is that the manual says 419liters ?
Jag vet varför engelsmän dricker varm öl
David.Mattsson
Maskin: JCB
#32 » 23:43:24, 01-06-2010
she is back on track!
David.Mattsson
Maskin: JCB
PB71
#33 » 00:18:58, 02-06-2010
I dont know what Hymac recommends but i think you can use 46 hydraulic oil, the 32 is most where its very cold longer periods ... Dont think you are going to dig so much when its -25C ?
Scania V8 det är grejor det ...
PB71
Maskin: Åkerman H25 nr 0022
Case 1150 Bandlastare
Volvo BM 1641
Scania R144 -01
Scania LA82B -61
Scania LBS 141 -78
Jima minigrävare
#34 » 21:58:43, 02-06-2010
ok i i think i will go for the 46 oil just fishing fore a god price right now
neade to start digging soon
Bild Tillägg efter 3 minut(er):
shell tellus oil 33 @ 0-27 deg
or mobil DTE light
David.Mattsson
Maskin: JCB
bert
#35 » 18:19:15, 04-06-2010
sweet then i come any day and take a test drive
bert
#36 » 22:44:54, 05-06-2010
you are welcome :)
208l hydralic oil and filter is changed + clening tanks but i nead more vill buy more on monday
engine oil and filter changed + injection pump oil
David.Mattsson
Maskin: JCB
Jeremy Rowland
#37 » 22:25:00, 07-06-2010
Hi David :wave:
Looks like your making a great job of your restoration :cool: Does the machine feel a lot better to operate since doing all the restoration work? Just a few cosmetic improvements left.
Here is a pic of a 580C that has recently been fully restored by a friend of mine over here, and believe me this machine has been fully stripped and rebuilt.
Jeremy
Jeremy Rowland
International
#38 » 23:33:29, 07-06-2010
for now i will not go forwad with paint :( i have som digging that i need it to do first
on the to do list on the macine before she go to work
1 finnish converting the leavers to standard with bom and bucket on right and dipper and turn on left hand
2 get new front and side windows (probably plexiglas)
3 mount the new driver seet from BE-GE
4 change the transmission oil again but neeade to drive it to make sure the motors aint leeking anymore.
Regarding the operation i hawent driven it yet du to the low oil level after the oil change.
probably will make a test drive on friday
nice macine buy the way that is what i need to se to keep up my motivation
David.Mattsson
Maskin: JCB
Jeremy Rowland
#39 » 18:15:00, 08-06-2010
Yes David I think its wise to do the digging before your paint job, incidently the standard control set up on a 580C is; the left hand lever, pull back to raise the boom and push forward to lower it, push it left to open the bucket and right to curl the bucket.
The left pedal to bring the dipper arm in and the right one to take it out, the right lever is forward to slew left and pull back to slew right with the auxilliary on the left and right.
My friend who has rebuilt the 580C is selling this machine, he has two more to rebuild and he did his apprenticeship with Hymac as a company. He has spared no expense in his rebuild, I have added a few more pics for all to see.
Jeremy
Jeremy Rowland
International
#40 » 23:22:08, 08-06-2010
Thanks for the pictures jeremy very nice to see a macine in that shape it shold be at museum :grin:
my macine will probably never be that nice but with som paint it migt look better than now but i consentrat on the mecanical first
i hawe a smal concern regarding my trac motors when i "drive" it forward i hawe a scoring sound that come and go ? i had the motors down for inspection and new seels befor my injury but havent realy driven it before.
i know that the previos owner has made some repair in the swirvel can it has somthing to do with that.... or wher to start maybe it s somthing to do with the T conection to the brakes?
anyway her is 2 picturs from todays first test digg outside my barn
David.Mattsson
Maskin: JCB
Jeremy Rowland
#41 » 00:36:38, 09-06-2010
Can you hear the noise if you raise the track off the ground and run it, or is the noise only under load?
I will ask my friend what he thinks when I get the chance.
Jeremy
Jeremy Rowland
International
#42 » 09:05:26, 09-06-2010
yes i can her it if i lift the trac its no diffrens with load it´s a bit better if i dont runn att hig speed "full lever" it dont seem to be affected buy the engine rpm
thankfull for all help
David.Mattsson
Maskin: JCB
#43 » 22:34:18, 11-06-2010
A litel Update
Fond somthing intresting under the Seet when i changed it
Think i need a bigger garage
David.Mattsson
Maskin: JCB
Jeremy Rowland
#44 » 23:32:29, 14-06-2010
Ahh yes a two headed bird, now you don't get to see many of those :lmao:
Jeremy
Jeremy Rowland
International
bert
#45 » 20:05:29, 01-08-2010
bert
Återgå till Hymac Technology
