I have a problem with the track tension. I guess that both idler and drive wheel together with the track itself is so worn out that it is difficult get the right tension.
I have replaced the sealings in the adjustment cylinders and started to pump in grease. But I think the piston rod soon is about to fall out of the cylinder.
My questions is.
Is it possible to remove one section of the track to make it shorter and in that case how is that done?
Secondly is there any other remedy for this problem?
