ForumindexMaskinforumThe Hymac ClubHymac Technology
Slew Motor Crank Shaft
4 inlägg • Sida 1 av 1
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
validum (trådstartaren)
#1 » 02:23:03, 22-06-2010
Crank shaft for Slew Motor broken, how often does this happen, what are possible causes , Too much load during slew?.it happened while turning with bucket of sand.
validum
Jeremy Rowland
#2 » 18:19:32, 22-06-2010
Hi Validum :wave:
I have heard of slew motor cranks breaking before, these parts are available so any problems let me know and I will try and put you in contact with somebody who can help you.
There is no particular reason for this as far as I know.
Jeremy
Jeremy Rowland
International
#3 » 21:53:19, 22-06-2010
Thanks jeremey.
I shall search for it locally first, actually I do have an immediate repacement , I recently got a complete slew motor from a local breaker, but would like to explore having Backup+1 on hand for further events.
Actually what is killing is the weight and thus cost of shipment from say Uk to Guyana, last time I bought a part it cost more than the cost of the part to ship and import taxes :!: ( which is charged based on (cost of item + cost to ship) sounds silly but true!
anyway many thanks ,
the machine is pretty old and we have been doing a lot of land clearing , moving sizeable trees and stuff( don't worry not hurting the environment) :smile:
Lloyd
Lloyd Validum ,Guyana
validum
RolfsRolls
#4 » 16:41:09, 20-05-2016
The slew motor is of make staffa. Cause to broken shaft can be to high setting of cross over relief valves.
I use tu buy used Hymac parts from Kenneth robsson equipmnt or Harry stenhouse Blackpool hydraulics.
RolfsRolls
Återgå till Hymac Technology
