ForumindexMaskinforumThe Hymac ClubHymac Technology
580C Mangled Track Gearbox
71 inlägg • Sida 2 av 5
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
Andy80
#16 » 18:49:57, 03-12-2018
Sorry for you man. Locks like you need a new transmission.
Lucky there are parts to get in your home country.
www.hydraulicplantservices.com
Andy80
Maskin: Hymac 580B
Antevante
#17 » 20:10:51, 03-12-2018
Sad too se. Axels gears and bearings is the easy part. If the housing has damage after the bearing collapse that could be a bigger problem. But lets hope for the best! Youre not the first with this problem. A bit of a classic 580 problem...
There is first a circlip on the brake axel thats stops the drum from sliding out. If you can get a pulley mounted on the brakedrum and give it some heat the key will probably come along aswell. Its just lockning the drum from turning on the axel.
/Ante
Antevante
Maskin: Volvo L70F (Anställd)
Hymac 580BT
Hymac 580D
dolmenman (trådstartaren)
#18 » 20:40:20, 03-12-2018
It is sad for me to see too....As you say, my biggest worry is the housing being damaged, although I am hopeful it is ok, as the damage happened quickly..
I think it is possible (according to the manual) to remove the brake pulley by screwing two 1/2" UNF threaded bolts into the pulley acting like a hub puller.
There is a breakers yard about 8km from me and he has at least a couple of 580c's and there are online guys, so sourcing parts isn't too difficult..
I'm sure It will be a job that gets gradually done, although my holiday will be spoiled as I will be thinking of solutions all the time, and not paying attention to my girlfriend...lol
I will update you guys as I proceed and will probably need more advice.
Thanks so far...
dolmenman
International
Maskin: Hymac 580 C
Antevante
#19 » 21:26:42, 03-12-2018
Its worth a try with the bolts!
We are all a bit jeulous thats you still can find Hymacs on a breakers yard :thummar:
Take good care of her! (The Hymac aswell) :mrgreen:
Antevante
Hymac 580BT
Hymac 580D
#20 » 12:42:32, 04-12-2018
The Transfer pinion is wrecked and the large gear on the output shaft is badly damaged...The carrier?housing for the output shaft is damaged but not too bad so may be able to rub it down and use Loctite 6 to fit new bearing...
The bearing has completely disintegrated.
I have posted some photos.
Can anyone tell me how to remove the "plug" for the transfer pinion, located between the track motor and the drive chain housing? It's in one of the photos secured with a circlip...The manual is not clear.
dolmenman
International
Maskin: Hymac 580 C
Antevante
#21 » 13:08:44, 04-12-2018
Well done. Seems like a long shopping list...
The plug is locked by the circlip as you say. There is a threded hole in the center that you can use to drag it out. It can be really hard to get it loose. My best advice is to take the plug away on the opposite side and hit the axel from that side. Then the plug will come out aswell.
/Ante
Antevante
Hymac 580BT
Hymac 580D
DH Service
#22 » 13:36:08, 04-12-2018
I can recognize that bearing seat for the final axle it looks beautiful! Or not !
DH Service
Maskin: IH 1246. Bm 350 Boxer.FMV 1600. Volvo bm 4300, Hymac 580c Mobilt arborrverk för entrepenadmaskiner /industri.
#23 » 16:22:21, 04-12-2018
Some more pics...
As can be seen, there is a lot of debris when I drained the oil...lucky the damage isn't worse.
Someone has been in here before as there is writing that says "bore out inner bush"...oh dear
Also, does anyone know the tread (1/4" UBF?) for the set screws to remove bearing retainer beneath brake hub?
Or a method to remove it?
dolmenman
International
Maskin: Hymac 580 C
findusthecat82
#24 » 08:43:43, 05-12-2018
I saw this thread recently. If you need to remove the outer bearing ring, strip the inner bearing ring and bearing balls. weld a Good bead on the surface of the outer ring, the hot bead Will make ring to shrink and make it easy to remove.
Skickat från min SM-A520F via Tapatalk
findusthecat82
Maskin: Åkersork H9
#25 » 10:07:24, 05-12-2018
Unfortunately, the machine is outside and the weather is too wet to work at it, and I'm going away for a few days...
I hope the welder will work as it's about 50 m from power source?
I'm not sure if part of the outer ball race is still in the housing on the frame and removing aforementioned plug seems to be a problem.
I wish I knew what thread sizes for the drawing bolts to remove transfer pinion carrier and the sealing plug..The workshop manual is no help..
The only good news is that I can get all the parts from England, which will be easier than the local breakers as I would probably have to strip them out myself.
dolmenman
International
Maskin: Hymac 580 C
PeterR
#26 » 13:35:32, 05-12-2018
Regarding size/thread of the drawing screws:
What threading system is commonly used at Hymac?
Can it be metric (M6x0,75)? Else, British BSF (1/4" 26) or the American UNF (1/4" 28)?
Looks larger in the pics.....
PeterR
Maskin: John Deere 1640 med Quicke Q930, Volvo BM T430 med Trima 1120, Cormach SC-2, Modig 190HF, Arboga U2508
Andy80
#27 » 16:58:26, 05-12-2018
Almust every bolt on Hymac is UNC or UNF. Correct me if im wrong
Andy80
Maskin: Hymac 580B
Antevante
#28 » 18:50:13, 05-12-2018
My guess would be som sort of unc threads. I can check in the weekend. Last time a took my gearbox apart it was on my 580D wich has millimeter threads.
The bearing retainer behind the brake often get a bit stuck beacuse there is a gasket behind that gets glued togheter with time. If you just knock it a few times and try to make it ”turn” a bit around the axel the gasket will let it go.
The big plugs on the chain side can be tricky. On my 580BT I had to weld nuts on them and drag them out. The old threads were almost gone.
Antevante
Hymac 580BT
Hymac 580D
#29 » 20:21:26, 05-12-2018
Ok..Thanks...I'm in Brussels at the moment so won't be back until Monday..I'm sure I will need more assistance..lol
dolmenman
International
Maskin: Hymac 580 C
#30 » 18:45:16, 11-12-2018
Ok...got a bit more done today, in between the rain...I knocked the bearing retainer round, as Antevante suggested and it came away easily...someone had used that blue, instant gasket paste, instead of a gasket..
I found a bolt from the brake cover fitted the big plug behind the transfer shaft, and have it almost pulled out, but someone has put a blob of weld in the space in the chain guard housing which stops the plug coming out completely It can be seen in the photograph as a bump over the plug..I may be able to grind it with angle grinder but it is too wet at the moment..
Just to make sure...The shaft hammers out towards the brake side?
dolmenman
International
Maskin: Hymac 580 C
Återgå till Hymac Technology
Olssons i Ellös
Briggsparts
UniCarriers
Rotec
Lunna Teknik
https://www.AUTOdoc.SE
