ForumindexMaskinforumThe Hymac ClubHymac Technology
Idler wheel assembly
4 inlägg • Sida 1 av 1
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
dolmenman (trådstartaren)
#1 » 20:23:32, 26-08-2019
I noticed the bushes were finished on the idler wheel of my 580 C but when I pulled the idler out, I noticed the bolt that is used to compress the spring was broken...All the second hand ones around here are also broken with the fork detached from the spring...will I have to get the broken bolt bored out or can I reassemble it without this?
dolmenman
International
Maskin: Hymac 580 C
DH Service
#2 » 23:05:29, 26-08-2019
I dont think it will fall apart if you assembley the parts and get it tight.
DH Service
Maskin: IH 1246. Bm 350 Boxer.FMV 1600. Volvo bm 4300, Hymac 580c Mobilt arborrverk för entrepenadmaskiner /industri.
#3 » 07:10:25, 27-08-2019
Thanks...today I will try..I'll let you know my progress...
dolmenman
International
Maskin: Hymac 580 C
#4 » 18:58:27, 27-08-2019
Got it assembled and so far so good...put a tack of weld between spring and support to make i5 easy to assemble, then fitted replacement fork and wheel which I got from breakers about 8km away...€120..the old fork had been rubbing against idler wheel so bushes well gone..Got a days work done so pretty pleased...
dolmenman
International
Maskin: Hymac 580 C
Återgå till Hymac Technology
