ForumindexMaskinforumThe Hymac ClubHymac Technology
HYMAC 580CS, Drive Shaft, undercarriage
5 inlägg • Sida 1 av 1
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
TurboTony63 (trådstartaren)
#1 » 13:43:16, 28-01-2020
Hello
Is there anyone ho has driveshaft for crawler, the bigger sort and drive wheel for crawler also?, i have chain sprocket wheel!
Long story but i will try to make it short!
Me and my friend has a 580CS that we transported over the ice :uupps: to our summerhouses on a island just outside of Karlstad in Sweden.
Our tracks were worn out and also splines on one of the driveshafts and drive wheel, to solve this problem(so we thougt) we bought driveshafts.
It was the smaller size that we get are hands on from a farmer outside of Karlstad and we started to modify the bearing houses to fit smaller bearings
The first that happened was that the shaft on one side snapped of inside of chain sprocket wheel after 30mins, so then we modified back to the bigger shaft and wheel and sprocket wheel.
We did only have one sprocket wheel for the smaller shaft so i drilled out a bushing from the large shaft with the splines on it an shrink fitted and welded it.
We monted this and it hold for 30 mins! :djaevul: Then we drilled in the shaft and bushing with hard metal drill and put in 2 backsides of 8mm drills and welded.
This time it held for 2 hours....so now we need to rebuild this shaft again, this time with original size.
This was only the story about the crawlershafts, let me remind you of that we are having the dream machine on a island so it was quite a challenge to get new tracks out to the machine :-)
Now to my question;
Br Tony
TurboTony63
Maskin: Hymac 580CS
Andy80
#2 » 10:53:42, 29-01-2020
Do you have pics on the broken parts, the repairs you made and also the excavator. It would be lovely to see :)
Jag har tyvärr inga delar, men ett stort intresse av Hymac :)
Andy80
Maskin: Hymac 580B
#3 » 16:54:36, 09-02-2020
Här är lite bilder
Here are some pictures
TurboTony63
Maskin: Hymac 580CS
#4 » 17:01:57, 09-02-2020
TurboTony63
Maskin: Hymac 580CS
Andy80
#5 » 17:18:47, 09-02-2020
Intressant med bilder, ser att splinsen ser slitna ut. Vet en annan kille som fräste ur ett krysskilsspår istället. Svetsa går ju med, men svårt få isär i framtiden då
Andy80
Maskin: Hymac 580B
Återgå till Hymac Technology
