ForumindexMaskinforumThe Hymac ClubHymac Technology
Front-top-window opinging, solution?
2 inlägg • Sida 1 av 1
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
GiZZmo (trådstartaren)
#1 » 07:19:50, 04-10-2012
Is there anyone that has a god solution to opening the complete top-front window?
Please with pictures
//Jerry G
GiZZmo
Maskin: Takejob 235 -09
Hy-mac 580BT
John Deere 644B
Valmet 665 - 96
Case 844xl -86
Deutz Dx 140 -80
Volvo Bm 400
Mercedes Sprinter 518 Be trailer -08
Nissan Kingcab höjd 9" med 37" -06
Sittåträng Berlingo -11
Jeremy Rowland
#2 » 19:13:50, 04-10-2012
Hi there :wave: from what I can recall the top window on the 580BT is a one piece window; however the two piece opening window from a 580C should fit straight in to your machine.
If your machine has already been fitted with a two piece window then it should push outwards, please note that sometimes the mechanism can stick with age so I would suggest carefully spraying the mechanism with a good quality freeing agent like WD40.
Hope that helps.
Jeremy
Jeremy Rowland
International
Återgå till Hymac Technology
