ForumindexMaskinforumThe Hymac ClubHymac Technology
Replacement filter element for Hydraulic filter
44 inlägg • Sida 1 av 3
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
validum (trådstartaren)
#1 » 04:54:19, 19-10-2007
Hello ,
Can anyone advise which filter element to use to replace the Hydraulic filter elements for the 3 hydraulic pumps on the Hymac 580C?
Validum
validum
pean
#2 » 21:27:17, 01-11-2007
pean
#3 » 05:44:04, 02-11-2007
Thank you I was able to get the crosland 7044A
Validum
validum
Nick Drew
#4 » 15:50:52, 03-11-2007
validum skrev:Thank you I was able to get the crosland 7044A
Validum
Hi Validum,
I am very pleased to hear that you have managed to find the correct filters for your Hymac :thumme:
Has it made the performance of your machine better??
Sure would be nice to see some photos of your machine here :buga:
Nick :mrgreen:
Nick Drew
International
#5 » 04:20:10, 04-11-2007
Hello Nick
Many thanks for your interest. I have not been able at to get it going yet because we are cleaning it up, I purchased it working, it is in very bad shape maintainence wise , very dirty and grime covered, We had to do a complete cleanup, ( two days scraping and pressure washing!) You would be apalled at the amount of stuff we had to remove, the cabin is in bad shape lots of rust and the electrical system all shot but it worked , It Moves ( one track ( swamp /Bog wide track)a little faster than the other ) and the rams operated ok but slow , ( I hope that the celanup of the hydraulics wil l sort that out the Hydraulic fluid was really bad white water logged/ and there was even water in the diesel, It has a ford 2713E engine and the water pump / Bearing was shot We were able to patch that up but could not find replacement part locally.
The cooling fins on the hydraulic cooler are rusted off for the most.
The pins and holes on the booms ) bucket end) are pretty worn and We are looking as " sleeving them" with something.
We are carefully going everything over and I will certainly post some pics later ( soon I hope) .
To fill in further this is a first for me , I bought it for Developing a 26 acre farm in wetlands because I really cannot afford to go for one of the other modern machines , also because of it's simplicity compared to the modern stuff. ( actually we got 2 machines at the same time on a deal , both working but in bad shape) (the other with a perkins engine( working also)
I am based in Guyana south america , This Used to be a British colony so we have many of these old machines here from the 1960's , mostly brought in by the then government and have now found their way into private hands and the scrapyard, ( they can be seen laid up in many farming areas rusting away, mostly stripped of the removble parts)
Most of the machines in use now are Komatsu/Caterpillar/Daewoo/Hitachi
I have a great mechanic who is capable of making anything out of nothing, ( he makes his heavy duty flat screwdrivers from old bedford truck leaf springs! and a grinder ) ( and flat spanners from 1/4 Inch plate steel (- cuts the shape of the bolt/nut head out of a length of the metal with a cold chisel ,( soundse nuts but that is how he has kept going in the bush all these years! with over 30 years experience in maintanence of heavy duty machines in the Jungles of Guyana. I am sure that he will keep the machines alive.
I will keep you posted on progress.
Validum
validum
Robban_C
#6 » 09:12:25, 04-11-2007
Thanks for the info! :thumme:
Any pictures of your machines?
Har slutat på forumet!
Robban_C
Maskin: Volvo EC45 -06
Volvo ECR25D -17
MB-Trac 800 -86
Valtra N174D -17
Nick Drew
#7 » 13:01:16, 04-11-2007
Hi Validum,
Wow!! Many thanks for the details about your machine and what you are doing with it....Can't wait to see some photos of it. :buga:
I was also very interested to hear you talk about the many old Hymacs that are lying around out there! Is there any chance that you could take some photos of any of them that you see on your travels?? It would be great to see them here in the Hymac section at Maskinisten and if you get the chance please post some at our Sister site www.classicmachinery.net/forum
Thanks again for your input :thummar:
Nick :mrgreen:
Nick Drew
International
#8 » 03:58:56, 05-11-2007
Hello Nick,
I will take some photos, How do I post them on the forum?
Validum
validum
Robban_C
#9 » 09:11:26, 05-11-2007
When you do a "normal" post like the ones you have done above you have buttons for uploading the pic´s below the textbox where you write the text.
The pic´s have to be smaller than 150 kb.
Robban_C
Volvo ECR25D -17
MB-Trac 800 -86
Valtra N174D -17
#10 » 12:32:19, 05-11-2007
ok here goes, this is one of the two, I'll get shots for the othere later as it is at another location
I'll also begin tp take shots of those I find along the way, I hope that these pics do not distress you all. ( the machines including mine are in pretty bad shape.( looks like I got the upload right)
validumBild[img][img]http://www.maskinisten.net/userpix/4614_580c2small_1.jpg[/img]
validum
Nick Drew
#11 » 12:41:13, 05-11-2007
Fantastic stuff Validum,
Thanks for posting!!! :thummar:
And no I am not distressed because at least the machine is still in one piece and not like so many poor old Hymacs in the UK that end up cut up for scrap :cry: :cry:
That is a sad sight to see :(
Keep the shots coming Validum :buga:
Nick :mrgreen:
Nick Drew
International
Robban_C
#12 » 16:29:44, 05-11-2007
There you see Nick, there are more people than just the Englishmen that use grading buckets that cannot tilt. :grin:
(Nick and I have had that discussion on CMN a long time ago)
And I really like that umbrella covering the engine compartment. Definitely a view for the "green guys" (the envorinmental guys). :mrgreen:
Robban_C
Volvo ECR25D -17
MB-Trac 800 -86
Valtra N174D -17
heinz
#13 » 11:56:36, 06-11-2007
Wow!
What a great engine lid on our machine!! :grin: :mrgreen:
Nice in hot areas I suppose!?
Henrik
heinz
Jeremy Rowland
#14 » 21:04:48, 10-11-2007
Hi Validum :wave:
Thanks for posting the shots of your machine, more please :bira:
As for the state of the machine all I can say is you should see the poor condition of some machines over here!
Thanks anyway, nice one!
Kind Regards,
Jeremy
Jeremy Rowland
International
#15 » 05:48:54, 13-11-2007
This one is in fair condition , not far from where I live, it has something wrong with the tracks ( left) I believe that is otherwise in working condition ,itBild
belongs to the local authority, I saw someone tinkering with the engine last week , the engine compartment has a padlock on it
The front window is broken
validumBild
validum
Återgå till Hymac Technology
