ForumindexMaskinforumThe Hymac ClubHymac Technology
Replacement filter element for Hydraulic filter
44 inlägg • Sida 3 av 3
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
Robban_C
#31 » 14:53:40, 27-11-2007
It was a sliding boom but I´m not sure if it slid hydraulically or if you had to remove some kind of pins to slide it.
Har slutat på forumet!
Robban_C
Maskin: Volvo EC45 -06
Volvo ECR25D -17
MB-Trac 800 -86
Valtra N174D -17
Jeremy Rowland
#32 » 15:32:27, 27-11-2007
Hi Validum :wave:
The boom was secured by pins, the length being set by option. Only JCB made a powerslide boom.
Jeremy
Jeremy Rowland
International
validum (trådstartaren)
#33 » 10:35:31, 02-08-2008
Hello Jeremy,
I just noted in one of you posts in another section ( answer to "some questions" 01/02/ 2008) that you have a HYMAC 580C Operations and Mainainence manual ,( would it be at all possible for me to get a copy of this from you, I would really appreciate it . the parts manual I had downloaded from the site has been of great help but the Maintainance manual would be great also . I currently have one of my machines working and unfortunatelly have had to take down the other for a complete overhaul since the hydraulid flluid ( engine is working fine) was completely saturated with water ( Milky white). we have since found that the system is really porous and water seemed to have been entering thru the cover plates and a "fill valve" some one installed on the top cover of the Hydraulic tank. ( by the way I had promised to post some shots of the work when we begin , i'll do so shortly)
As we are on this note can you say what is the fill capacity ( litres/Gallons) for the Hydraulic System for the 580C when filled to the "normal" leve on the Hydraulic guage?.
Lloyd Validum.
validum
Jeremy Rowland
#34 » 00:41:56, 03-08-2008
Hi Validum,
The hydraulic oil capacity for a 580C is 93 U.K. gallons (422.77 litres), I will try and get the relevant parts of the maintenance manual copied for you. There are some parts which you won't need for example how to operate the machine and also the parts manual in the back.
My problem is having the time to scan it all in and I only have a dial up connection it might be quicker for me to burn all the scanned info onto a CD and post it to you?
Jeremy
Jeremy Rowland
International
#35 » 04:43:16, 03-08-2008
Hello Jeremy,
that would be great,
should I send you my mailing address by a direct e mail?
Lloyd Validum
validum
#36 » 06:23:01, 08-08-2008
Hi Jeremy
I realize that this can take up time, and I do not mind covering the cost of you having it done for me if you can locate a shop where this can be accomplished.
Lloyd Validum
validum
Jeremy Rowland
#37 » 19:57:53, 08-08-2008
Hi Validum :wave:
If you pm me your address then I will get the manual scanned and put on CD for you.
Holger I can also send you a copy so you can post it on this site.
Jeremy
Jeremy Rowland
International
#38 » 02:55:53, 10-08-2008
Hello Guys,
This must be a dumb question, Can someone please tell me which is the "front" of my 580C undercarriage, is it the side with the gearbox and walking motors or the side with the idlers.
To follow, when I walk or manuver the machine ( ie climbing a slope or turning)which side should I use ( i mean for me either side can be the front if I swing the cabin!.)
Lloyd Validum
validum
Jeremy Rowland
#39 » 15:42:48, 10-08-2008
Lloyd the front of all Hymac machines is taken from the Idler wheel and not the drive sprocket, so I hope this simple matter is clear to you now.
:wave:
Jeremy
Jeremy Rowland
International
#40 » 02:34:20, 05-09-2008
I saw this one recently a 59? something I believe it had marked on the side
Nostalgia? two old work-horses side by side again
A Massey Ferguson 35 vintage tractor and a Hymac 580C working together again!
going home after a good day's work/
note the white sand surface
This one's down for repair , we stripped the hydraulic system , hoses dangling
Water in the hydraulic oil, we'll replace it all.
lloyd validum
Lloyd
validum
Conrod
#41 » 23:18:19, 13-08-2009
A cross referens for Hydralic Filter Catridge that should fit is Baldwin PT676 or Cummins Filtration HF 30724 :wink:
Conrod
Maskin: Scania P82H
Kallsmed
#42 » 18:54:43, 10-08-2017
Is it possible Hydralic Filter Catridge Baldwin PT676 or Cummins Filtration HF 30724 is also suitable for 580B?
Kallsmed
1 inlägg
Maskin: Hymac 580B
Jeremy Rowland
#43 » 20:32:00, 10-08-2017
Robban_C skrev:It was a sliding boom but I´m not sure if it slid hydraulically or if you had to remove some kind of pins to slide it.
The boom sliding on the Hymac machines was not hydraulically powered; you took out the pins then probably operated the dipper arm to move the boom to the required position.
Jeremy
Jeremy Rowland
International
Antevante
#44 » 21:42:55, 10-08-2017
Kallsmed skrev:Is it possible Hydralic Filter Catridge Baldwin PT676 or Cummins Filtration HF 30724 is also suitable for 580B?
Yes It should fit. I have HF30724 on My 580BT wich is the same machine as 580B except for the undercarrige.
Antevante
Maskin: Volvo L90H (Anställd)
Hymac 580BT
Hymac 580DS
MB Trac 800
Återgå till Hymac Technology
