ForumindexMaskinforumThe Hymac ClubHymac Technology
Some questions
57 inlägg • Sida 2 av 4
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
Nick Drew
#16 » 14:55:02, 02-02-2008
Yes Well done Jeremy!!
I had forgotten about the fact that there may of been a drain plug under the Hydraulic tank ....My memory is not what it was !!! :lol: :razz:
I haven't worked on a Hymac for over 14 yrs !! and the last one was a 580D so a bit different really.
Its a good job you are here Jeremy :buga:
Nick :driver:
Please check out my blog http://www.earthmoversmagazine.co.uk/?page_id=3092
Join the Digger Man Blog Facebook page, click on this link to apply to become a member https://www.facebook.com/groups/1422908344617046/
Nick Drew
International
rune stewen
#17 » 20:53:52, 02-02-2008
Hi Robert. :wave:
Nice to read about your Hymac.
I did the operation, you are going to do, for about 1 month ago.
I will make you aware of the fact that almost 400 liters of hydralik oil are pressing on the drainplugg and it is not so easy to replace the plugg if you want to interrupt the flow.
My recommendation is: open the top of the tank and use a pump for the main part of the oil, then you can open up the drainhole to emty the tank completely.
Don´t forget that there are alltogether 3 tanks in the hydraulic system and at least the main tank and the suctiontank (located just below the 3 pumps) is worth cleaning.
I found that the dumptank was clean compared to the main- and the suction-tank.
saved the oil by heating it up to 95 degrees C to get rid of the water and then I pumped it through a 10 micron filter. After this action, the oil was like new and I saved about 8000 skr. :thumme:
best regard Rune
rune stewen
Peter351
#18 » 21:34:01, 02-02-2008
Hello again!
I did that , opened the tanktop on main and suction and I found
about 10liter with dirt, the oil looked bad and aloot of water, so doit
right the first time.
I found that it is big diffrens in the price of oil, so call around
and check the price, last time i bought 2 barrels with ESSO
for about 11kr per liter.
Buy barrels.
Try to buy throu a tractor, truck workshop, they have discount
and maybe you dont have to pay tax (moms)....
I have a friend working at a big dealer, when they do first service
on new machines after 100-500 hours they change the oil and he put
that oil in barrels and I pick it up for coffemoney.....
then I filter the oil with a pump and a big 15micron filter.
You just have to trust your friend.....
Regards Peter
Volvo EC140LC
John Deere 2040 S 4WD
Ford 8000
+ objekt...
Peter351
Maskin: volvo EC140LC
JD 2040s
Ford 8000
Hydrema
Allis Chalmers B
mm mm mm
Robert Strømmen (trådstartaren)
#19 » 15:36:03, 24-02-2008
Hello everybody. I am a little confused. Is every Hymac 580BT delivered with the Ford 2703E, or is there other engines too? Is there any models with 24V syetem? Mine has two batteries in serial.....??????
Hymac 580BT
Robert Strømmen
Jeremy Rowland
#20 » 16:20:50, 24-02-2008
Hi Robert,
The standard engine fitted into Hymac 580BT is the Ford motor. This was the same engine that was fitted to 580/580B models and later 580C models.
I do know that Hymac also fitted Perkins 6.354 motors in some 580C's and also in other models such as the 590C etc...
The standard electrical system on the 580BT is a 12 volt system, however it is possible that Hymac made some 24 volt machines but I have no evidence to back this up.
Hope that helps you please post us some pics of your machine. :thummar:
Jeremy
Jeremy Rowland
International
#21 » 16:53:45, 24-02-2008
Hymac 580BT
Robert Strømmen
rune stewen
#22 » 20:22:07, 27-02-2008
Hallo Robert.
Have your dieseltank been opened for repair?
On the picture it looks like the front have been opened.
My hymac 580C leaks from the tank if I fill more than 100 liters. It is internal and I can not find were it leaks.
Do you have any experiance?
mbh rune
rune stewen
#23 » 18:52:44, 28-02-2008
Hello Rune, the plate you see is not the dieseltank. it is where the batteries is inside. i dont have any idea where your diesel takes the way....
Hymac 580BT
Robert Strømmen
#24 » 18:54:53, 28-02-2008
Anyone who has seen pictures of Hymac with orange and black/grey painting? I think i want to do that with mine..... :thummar:
Hymac 580BT
Robert Strømmen
Anders Berg
#25 » 19:06:10, 28-02-2008
Hello, idont know if it´s something like this you´re thinking of, but i show a picture of my Hymac anyway, it´s a Hymac 580B tuned up with two shift controls, another door, new interior mm.
Anders Berg
Maskin: Volvo BM 4200
MF Robur
Brøyt X21
Volvo N10
Scania 76 Super
Volvo FM 12 Spol/slam
Volvo FH 480
Volvo L70F
#26 » 19:12:14, 28-02-2008
Thank you for Nice pictures, something like that, the original green is horrible.... Can you show me more pictures from the inside, engine and so on... What do you mean with two shift-controls?
Hymac 580BT
Robert Strømmen
Anders Berg
#27 » 19:57:43, 28-02-2008
Hello, sorry i don´t have any picture of the engine, but it´s a Ford engine like most of them have. I show you the pictures i have from the inside. From the beginning there was three shift control and pedals on the floor, but i changed it, as you can see on the picture, to two shift only, and no pedals. The door was strange, you pushed it backward to open it,( skjutdörr) so i changed it to a regual door (upp hängd med gångjärn)
I Agree, the green color is horrible, maybe some of the english Hymac engineers asked their children what color they should paint the machine :P
But look at the picture when i´m working on the machine. The red color my machine was painted in, looked like someone just painted their house and then decided to paint the Hymac with the color that was left. it was awful, i have bad dreams about it.
Anders Berg
MF Robur
Brøyt X21
Volvo N10
Scania 76 Super
Volvo FH 480
Volvo L70F
Holger
#28 » 18:19:48, 03-03-2008
Niiiiice! Nice colors also! ;-)
Holger
Webmaster
Webmaster
Maskin: Test
#29 » 15:57:48, 17-07-2008
Hello everyone. now i have removed the house of my machine, and all the rust is soon gone.... ahh... but i wonder how i can build the shift-controls from 2 controls and pedals- to only 2 shift-controls with the right function as all other macines have. Maybe Anders Berg can post som photos of his macine? :?
Hymac 580BT
Robert Strømmen
Anders Berg
#30 » 16:45:29, 17-07-2008
Hello Robert
I will writw the answer to you in swedish, our english Hymac friends must excuse.. :)
Jag har tyvärr inga bilder på själva ombyggnaden och maskinen är på långtidsprojekt i en kompis sommarstuga. Men så här är det, jag hade turen att få tag i ett komplett spakställ med länkage och allt som behövdes av en som byggt om sin maskin till servospakar (CT modell?).
Det passade ändå inte rakt av, utan man fick korta nåt stag och förlänga nåt annat. Men i stora drag passade det bra. Det gjorde inte saken enklare av att Hymac ingenjörernas främsta uppgift verkar ha varit att krångla till det och tro att "ju fler stag och länkar ju bättre blir det" :cool2:
Men med lite pysslande gick det bra. Och blev bra också, ett helt annat flyt i grävningen. Men som sagt, försök hitta ett komplett spakställ, eller se på någon maskin hur det är gjort. Annars tror jag det blir svårt att klura ut hur det ska va.
M V H
Anders B
Anders Berg
MF Robur
Brøyt X21
Volvo N10
Scania 76 Super
Volvo FH 480
Volvo L70F
Återgå till Hymac Technology
