ForumindexMaskinforumThe Hymac ClubHymac Technology
Rollers will not roll
6 inlägg • Sida 1 av 1
Discuss Hymac technology here.
Diskutera Hymac-teknik här. Obs! Forumet är på engelska!
rune stewen (trådstartaren)
#1 » 19:11:56, 06-04-2008
Hello!
Now the bearings and the chains in the driving assembly are new on both sides.
The gearboxes and brakes are overhauled, the tracks have got a lot of new bolts to keep the trackpads in place.
The hydraulic system have got all tanks cleaned, new filters and clean oil.
Everything should be allright but it is´nt.
The roolers, there are 18, and 7 of them are not turning, 3 on one side and 4 on the other side. How bad is it?
I can´t get the bolts, keeping the rollers to the undercarriage frame, loose.
When I prolong the wrensch with a pipe the bolts breaks and I have to drill it out and then make new threads and that is not an easy thing to do.
Do you have any suggestions how to get rollers rolling again, without taking them down from the frame or how to loose the bolts without breaking them.
best regards Rune
rune stewen
dea
#2 » 19:37:50, 06-04-2008
Is it possible to heat the bolts and then try to loose them?
dea
Maskin: IH 685
JD 6910
JD 6310
Fendt 815
BM 641
Nick Drew
#3 » 22:08:19, 06-04-2008
Hi Rune, & Dea,
I was once told of a technique to free stuck rollers :wink:
Begin by slacking off the track, then insert a strong piece of timber so that the rollers are in contact with the wood, then with the weight of the machine on the timber try moving the track backwards and forwards and in some cases this is enough to free them.
If this fails then you will need to strip them off and possibly replace them, or find a track repair centre to have them reconditioned.
Hope this helps :thummar:
Nick :mrgreen:
Nick Drew
International
#4 » 21:19:25, 07-04-2008
Hi Nick and Dea!
Thank you for your good advices :buga: .
This morning I tryed the timbermethod and after one hour, there was just two rollers still not turning.
Those two rollers I had to strip from the frame and by heating the area around the bolts, six of the bolts gave up and came out in one pice. Just two needed drilling and new threads :grin: .
I have also found a scrapyard selling rollers for 80 euro.
Worked better then expected :thummar:
Rune
rune stewen
Nick Drew
#5 » 21:46:35, 07-04-2008
Thats great news Rune :thummar:
Glad it all turn out well :wink:
Nick :cool:
Nick Drew
International
drivax
#6 » 23:04:00, 06-10-2009
I think that älmeboda maskinservice has restorde rollers for ca 800sek +moms
man är inte småläning för det är roligt!!
drivax
Maskin: Bm 646
ih 674
bm 230 victor
SMW drivax
Återgå till Hymac Technology
