Hello!
I bought it just before the summer and I´ve just started to repair it. There is a lot to do if you look at the pictures. The main problem right now is a drive shaft. I haven´t taken it apart by myself and got the things in a box.. Now I want to buy some spare parts and put it together again so I can use the machine. I looked on Downloads here on Maskinsten och Hymac 580 c parts manual page 15. It looks like it´s the same but the problem is that my Hymac is a BT and the parts manual is a 580 c? Could it be the same under carriage? I want to clear this out before I buy spare parts. The diameter inside the driven sprocket is 70 mm.
Thanks for your help!
Thord
