Hello everybody! I posted some pictures in the presentationpart of the forum a couple of days ago, but I´d like to show you some more pictures on the ongoing "makeover" of my Hymac 580CT -80
This is a couple of pictures after we bought it:
I´m a courius guy and before we start digging, I´ll like to know the status of the machine so we have started to check the electrical system and we have mounted some new lamps and we will mount a couple more (will Xenonconvert those later). We have painted the boom and dipper arm and I made some new decals for that one too. Today I dismounted the cover over the chains... They we half full with water... Lucky it was filled with grease, I´m cleaning this area, and will grease the chains and I´ll mount new gaskets too.
Here´s some pictures that are a couple of minutes old:
New decals and black Hammeritepaint
A LOT of mud has been removed...
Some new black paint here too. I suppose there has been some kind of cover on the box at the right of the motor, does anyone know how it should look?
Was half full with water but I think it looks quite good in there
Looks like it´s worse, but the "rust" on the chains was easy to remove. The chains seems to be "slack", might change that one later on.
Some sanding and painting on the machine will be done too
I´ve been studying the repair handbook (that I also uploaded in the Hymac downloadsection here) but I´m not really sure what´s behind the brakebox cover, is it any oil or can I remove the cover without getting "attacked" by oil or anything else?
