Volvo BM 616B TD60
16 inlägg • Sida 2 av 2
Gibrill (trådstartaren)
#16 » 01:27:11, 12-02-2024
fretchi skrev:I wouldn't worry too much about the transmission. The HT65 is sturdy, and was - as you previously said - mated with both D50 and D60 in wheel loaders 840, 841, 845 and 846
But don't expect a TD60 swap to be cheaper. Even though you can buy the motor for half the price, there are likely a lot of auxiliary components that needs replacing and/or modification.
You reassure me about the gearbox!
I owe it to myself... I think I have to remove the fan and put a modern truck electric spal on the radiator, redo the engine mounts and maybe cut the oil pan so that it can pass level with the gear Before ? some electrical probe wires and I think that's pretty much everything?
the original D42 radiator is very big and the hydraulic pump fits on the gears I think?
I'm a welder, that's why I think it will be easier to adapt
Envoyé de mon Pixel 7a en utilisant Tapatalk
Gibrill
International
Maskin: i have bm 616
