Norsk Hymas / Hymax / Valmet/Valtra produsert i Brumunddal, Norge
442 inlägg • Sida 27 av 30
Norwegian6x6
#391 » 23:10:52, 08-03-2015
Infoskilt hvordan en opererer teleskopfunksjon :)
Norwegian6x6
Norge
Maskintyp: Kran
Maskin: kran/ lastebil
HYMAS-HYMAX (trådstartaren)
#392 » 01:04:31, 15-03-2015
Heh....sånn oljegearkasse klistremerke hadde jeg for 30 år siden.
**God natt**
HYMAS-HYMAX
Maskin: HYMAS-HYMAX
Valmet8200
#393 » 13:16:41, 27-03-2015
A couple of questions ...
Where the hydraulic rough Strainer Valmet 8200?
The accumulator pressure Valmet 8200?
I am buying a new accumulator and it should load the right pressure.
Valmet8200
Suomi Finland (finska)
Maskintyp: Grävlastare
Maskin: VALMET 8200
#394 » 13:21:14, 27-03-2015
What is rough strainer?
I dont have information about accumulatorpressure...... but is the servopressure 20 bar? I guess your supplier should find the correct type from that.
HYMAS-HYMAX
Maskin: HYMAS-HYMAX
Valmet8200
#395 » 13:32:08, 27-03-2015
I mean hydraulic suction filter. Marked picture red line.
Valmet8200
Maskin: VALMET 8200
Valmet8200
#396 » 13:36:41, 27-03-2015
Ok, Thanks for information.
Valmet8200
Maskin: VALMET 8200
#397 » 15:29:57, 27-03-2015
Ok. I guess the suctionfilter is inside the tank. It's like that in other models.
HYMAS-HYMAX
Maskin: HYMAS-HYMAX
#398 » 21:58:54, 26-04-2015
Valmet8200 skrev:The accumulator pressure Valmet 8200?
General rule about accumulators : 90% of lowest workingpressure. Is it 20? 30? Bar in 8200 ?
If 30 Bar load with 27 Bar.
We're installing a new hydraulic aggregate where I work.
It's some pressure switches in the system and the acc. is loaded with 90% of the lowest one .
HYMAS-HYMAX
Maskin: HYMAS-HYMAX
#399 » 19:33:59, 29-04-2015
Husk Vei & anleggsmessen !
http://veioganlegg2015.linkevent.no
Dette er kun hvert 3dje år.
I 2012 så hadde Norsk Vegmuseum stand med maskiner fra Hymas, Brøyt, Øveraasen osv.
HYMAS-HYMAX
Maskin: HYMAS-HYMAX
#400 » 23:28:28, 08-05-2015
Hej, hej allihopa, välkomna til Vei og anlegg 2015 !
HYMAS-HYMAX
Maskin: HYMAS-HYMAX
Lazer
#401 » 21:34:24, 06-08-2015
Hymax skrev:
Lazer skrev:Ganska utmanade att byta svängkrans .Jag har själv nyligen kastat om ordningsföljden på tryckslangarna till pumparna för att få en inblick i var felet finns när högra larven blir slöare med varm olja. Drivmotor? Ventilbord? Eller pump?......
Det kan också vara tätningarna i sviveln som börjat läcka , har hänt några gånger.
Har (tyvärr) nog varit med och bytt svängkrans fem gånger på olika Hymax 940 . Svängkransen är inte en svag punkt på Hymax men dom får väldigt mycket stryk när vi plöjer jordvärme.
6 Augusti 2015.Det verkar faktist vara sviveln som läcker .När ena larven börjar dra sämre så hjälper det att svänga övervagnen 10- 15 minuter åt ena sidan.Men med material i skopan så räcker inte marktrycket till för den andra larven som börjar slå runt.Frågan är var man hittar tätningar till sviveln ,kan det vara någon mekanisk nötning där och är det mycket svårt att byta tätningarna? Tacksam för svar.
Lazer
Maskin: Valmet 8200 -87
#402 » 22:44:19, 06-08-2015
På eldre modeller var det tetninger av merket Merkel Rotomatic.
Det er mulig at http://www.180.no/firmavis/10059906658531.htm kan ha disse, evt hymax.no eller sylinderakutten.no
HYMAS-HYMAX
Maskin: HYMAS-HYMAX
perjarle
#403 » 22:58:42, 09-08-2015
her er min hymas 31(78).montert på volvo bm 700
perjarle
Norge
Maskin: bolinder munktell h10
volvo bm lm841
volvo bm 700 hymas 31
volvo bm 650 skogsrigget
volvo bm 650 med moi d1 dumper
volvo bm 430
volvo bm 400 med hymas 4 gravemaskin
#404 » 23:19:26, 09-08-2015
Ta et bilde fra andre enden.....er det Hymas skjær også ? "Type S"? Prodnr ?
HYMAS-HYMAX
Maskin: HYMAS-HYMAX
Tomas Guttulsrud
#405 » 00:56:22, 10-08-2015
En spesialare av en Brumunddøl observerad i Bäckefors
Tomas Guttulsrud
Norge
Maskintyp: Redskapsbärare
Maskin: Lundberg 7240
Airman ax52
Valtra N163D
