ja-bond77 skrev:Verkar som det finns möjligheter att justera strypningen här, fyra alternativ. Men vad är det man justerar? Förstärkningsmultipeln? Reaktionstid?
Dear Mr. Lindfors, Thank you for your e-mail.
Based on the information that you have provided us with, it seems that instead of valve with 5 ports, mistakenly valve with 4 ports has been supplied. There is a connection between the chambers НТ и EF, which can be closed with special plug М12х1, pos. 6 from the drawing below. In your case the plug is missing, meaning that currently these 2 ports are connected. We can send you the missing plug, the connection between the ports is threaded, so you just need to tight in the plugs, which will solve the problem.
Attached I am sending you a video visualizing this procedure, the plug in question is the last part that is disassembled during the disassembly process of the video, in your case this plug is missing.
Please let me know if you would like us to send you the special plug so you can insert it.
Looking forward to your feedback.
Best regards,
Lyuben Yotov
Expert Marketing
M+S Hydraulic PLC|BULGARIA
Jac skrev:Jag vill gärna se alla dysor i och runt kompensatorsliden.
