LM 840 needs new Brakes
15 inlägg • Sida 1 av 1
BOLT (trådstartaren)
#1 » 14:12:55, 28-06-2017
Hello from Austria,
i have an Volvo LM840 4WD, from 1969, still up and running. Now the brakes need to be serviced.
The part number 5 falls down, the brake was without function.
Thickness of disks measured: 11,2mm
Maybe the Cast-Iron plates (number 2 and the outer ones-not on picture) are worn out and new break-disks(number 7) do not affect?
What is the best way to renew this brake system (without buying a new wheel loader) ?
Greetings,
Uli
BOLT
International
Maskin: LM840
#2 » 21:37:11, 28-06-2017
Ingen som har nå tips på hur han ska renovera sina bromsar? Tror nr 5 gått sönder.
Is nr 5 broke or missing?
#3 » 21:53:18, 28-06-2017
Hello,
Nr. 5 is not missing, not broken!
Greetings,
Uli
BOLT
International
Maskin: LM840
#4 » 22:13:49, 28-06-2017
So what happens when you apply the brakes?
Nothing or is nr 5 falling down on the ground?
#5 » 22:30:10, 28-06-2017
Sometimes, when i press the brake pedal, Nr.5 falls down, brake pedal has no pressure. Then i have to open the brake disks and put nr. 5 back.
Then i adjusted the brakes a little bit thighter, adjusted both brake cylinders.
Now is the question, which parts should i renew?
Greetings,
Uli
BOLT
International
Maskin: LM840
#6 » 00:27:11, 29-06-2017
Ok så när han bromsar ramlar nr 5 bort ur sitt läge så han får ta isär o sätta den på plats igen.
Vad är slitet, är det lamellerna?
#7 » 00:43:37, 29-06-2017
#6 is holder springs for pins #5, is there in place?
Framtiden var bättre förr..
MN
#8 » 08:18:49, 29-06-2017
#4 are in place and in good shape? #2 moves freely back to starting pos when brake is released?
M
MN
#9 » 12:49:35, 29-06-2017
#4 is in good shape.
#2 moves freely in both directions. What is the minimum thickness of this part? Maybe too thin?
Springs and Clamps in good condition and in place.
Greetings,
Uli
BOLT
International
Maskin: LM840
Björn.O
#10 » 14:31:22, 29-06-2017
TK traktordelar might be able to help you with both new and used parts.
http://tktraktordelar.se/en/
Maybe they can help you with the minimum thickness of the brake discs too. The outer cover plate can be machined flat and it will be like new.
Björn.O
Maskin: Volvo BM L70 -90
Volvo BM 4500 -83
Clark 75B -81
Hydrema M1100C
Scania P92 lvx
Scania R143 lvx
Bandvagn 271 (Iller B-100)
MN
#11 » 15:11:56, 29-06-2017
and what about #6?
M
MN
#12 » 16:23:42, 29-06-2017
Hi,
i found out that new discs measure 12,5mm.
Machining the outer plate is a good idea, i think, i will do that.
What about the inner one?
# 6 are ok.
I turned OUT the screws(not on the picture) outside the brake, which are pushing on #2 (M12x1,25),
this tightens #5 and #8 a little bit more.
I will see, how long this will work.
Greetings,
Uli
BOLT
International
Maskin: LM840
Husråa
#13 » 00:33:52, 27-07-2017
Íve had the same problem on a Ferguson,
(same type brakes)
new brake disks diďnt help..
i found out that the play was to big so that the balls had lost the power at the end of the stroke.
fix with chimming to thicker brake disks
hope you understand..
my swenglich
Husråa
Maskin: MB Trac 800-80,Valmet 500-68, Belarus 505,T31Lowrider Allis chalmers D grader (väghyvel)-49 ? BM 230 Bamse -59 Spindelgrävare Kamo X3-?
#14 » 20:46:33, 30-11-2017
Hello,
we tightened some screews, reduced the play from the pedal to the brakes on some screws, it works ;-).
Greetings,
Uli
BOLT
International
Maskin: LM840
#15 » 10:44:57, 09-02-2018
Hello Husråa,
where did you get the thicker brake discs?
Greetings,
Uli
BOLT
International
Maskin: LM840
