well the weather's been exceptionally kind for a few days
yesterday started with a fueling session .... Druid style .....
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170508_11_17_10_Pro_zpsvsdf6l7z.jpgOriginalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170508_11_31_55_Pro_zpsqy7mlhsm.jpgfollowed by lashing the VA-r back on't dipper ..... had some tidying to do so's I could re-locate some pallets of ... all sorts, to get it out the way for an onslaught
.... hell it takes time to get it mice and flat/level
and shift it all !!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170508_13_31_13_Pro_zpskgb0kkyg.jpgOriginalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170508_16_52_24_Pro_zpsjwijlblt.jpgto a point that can still get about and get at what i want to remove ...but eventualy dropped the forks off and stuck a
bucket on again for some spoil shifting.
got the areas where the pallets
had been trimmed up and flat for a
stand for some real shifting today.
Alex arrived late afternoon with .......
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170508_19_07_21_Pro_zpszw7fjdph.jpgthe HPX ......
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170508_20_19_32_Pro_zpsfmbc3hhs.jpgthat's developed an annoying leak !
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170508_20_19_09_Pro_zpsyfhgn1zg.jpgthese took some getting out ...... and even more getting back in after sussing they were in one piece !!!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170508_20_38_35_Pro_zpsm2nwmnby.jpgeventually concluded that the cause was the 8.8s from Mr Kins
..... the head plate was far from the VFT it was, when it got fitted onto Matilda and I'm guessing that the slight movement was allowing/causing
oil to bypass the push fit seals !!
So the 8.8s are now
EFT .. any more and they'd snap .. and some 10.9s are required to replace 'em ... I reckon they're stretching allowing them to slack off, the head to move and hey presto .... leaky seals !!
'Course this is designed to hang off a rotater, vertically, not get man handled on the end of a dipper, in a quicky !! Pity there're no dowels to locate it, as the 17.5 mm holes the M16s pass through do not help the cause of keeping it stationary !!
So a shufty at that took care of yesterday evening, after tea ....
this morning was .... a late start
... Tuesday = (a) Clara day .... and an early finish, due to it being my fortnightly infusion night, so 5 o'clock bath-time!!
Did make full use of the sunshine though ... as much as I could, between waving to the lil' 'un, etc.
digga digga Grand dad" .... she's got the interest anyway .... for more than just the Thwaites !!
Left the VA-r on this morning for dealing with the back batter and creating a new level to cut down to .... with a bigger bucket ....
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170509_14_39_59_Pro_zpsurcvrnq6.jpgbut did manage to rack up some more on the counter ......
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170509_17_41_35_Pro_zpsla2apbwk.jpgAlso discovered a repair to get done .... again !! ..... this
pin is obviously taking some serious stresses and may have to consider a floating capture for it, to try and overcome the break for the second time
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170509_17_29_44_Pro_zpspwo3qcoo.jpgBit annoying, but 'tain't gonna fall apart ..... need to dig that drainage channel really, 'fore I drop it off, in favour of my favourite 3 ft edged Geith for some real ripping out down to the new level.
I like to try to maintain a usable set of levels, as yer never know when action is likely to be curtailed ..... by the bloody weather .. and that can happen anytime !! Gotta have
summat to stand on!!
a 15" reduction doesn't half create some loads too ......
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20170509_18_01_12_Pro_zpslnvwe661.jpgWould like to see this right across to the ramp and pull that down a bit too, hopefully, by end of
play tomorrow ........
the pallets of 'stuff' can stay sat at their
current levels now .... 'til I get this all down to where I want it and a surface on it ..... then I can pick said pallets down onto the bottom level ... as I'll have somewhere to stand the damned things
Lots more pix for the masochists amongst you in the usual place ......
http://s1275.photobucket.com/user/v8dru ... AND-page=1 link to the Bucket ...... which has been a complete PITA lately
.... they're '
experiencing issues' apparently!!!
Not as many as I am, trying to upload!!!!!
