lagun49 skrev:Are the "lamps" LED devices?
Yes Boyo .... small 10W flood type units ... do you know something I don't/should about these?????
been out to a mate's most of the day, helping him
strip a gert machine that needed two pairs of eyes/hands/brain cells.
didn't get back 'til gone four and have had a couple of hours investigating.
before anyone asks ... it has a full and complete earth
circuit, right the way back to the consumer unit in the house ?
Cannot find any leak with a meter across circuits or switches?
replaced the pull cord
switch .. no difference ..... had the 2 way rocker out of circuit and meter-ed it .... sod all .....
the flash rate is approx. every three seconds and so dim you need to be up the ladder next to the unit to see it.
meter across live and neutral gives zero to 46 volts, building over the three seconds .. LED triggers, return to zero and builds again .. etc., etc. .... it's just like a capacitor charging
Isolate the circuit at the MCB .... zero Volts at the LED and both switches, so it's somewhere in that circuit, but shows zero
cross talk between any line with a meter ??
I have three points at which I can meter it over the length of all the circuits, between the house and the shed and two more at the shed end .... all showing zero cross talk with a 2 meg Ω test ??
..... then the bell tolled and it was tea time
I might try replacing the LED unit with a
bulb holder and tungsten bulb and see WTF I get then
..... but can not for the life of me see how the
voltage is arriving and building slowly over three seconds, at the LED unit
with both switches in the off position ??????? Inducted voltage over the length of the two
control wires between the switches ... about 100 ft ?????
there is a constant live at the
L1 poles, in both switches, running beside the
L2 and
common leads
'S got me foxed ......... for now at least .....
'sposed to piss down tomorrow, so leccy fiddling'll be out the
window,
if it does and'll probably be over at Simon's tomorrow rebuilding said lump, if he gets a couple of bit's mod.-ed tonight
there is summat odd about these things, for sure
.... just been out and locked the shed (
as I forgot, after tea ) and having turned the 3 strips on inside, when turned off, they took a good minute to stop glowing to the point I couldn't see them
not bad light off the little floods though .... only 10W ones (
see WTF you are type thing) and a very respectable amount of light from them
got some bigger 50W ones I haven't tried yet
.... be interesting to see what level of light they emit .... 'sposed to be equivalent to a 500W halogen
more than happy with the strip lights .......
without the overhead storage in the way it'd be some bit bright in there
