right then fellas ........
well it did pee down night of the 17th ....
but the ground was not the greatest anyway, Sunday morning, so didn't get to do anything .....
plus, ..... I hadn't been feeling the greatest either, since head butting yon Hill ...
Was gonna have to have my shit together Monday morning though ... promised the neighbour I'd go lift some bits for him.
Gave him my old gas compound, when I cleared the yard out ... better than skipping it, for what it was ultimately worth in the bin and he's finally gotten around to putting some pads in for it, to stand it on, last week.
Going to create a traccy/machinery shed with it and a few extra poles and roof sheets ..
So was hoping the 'Drema behaved itself ....... and his field wasn't too wet !!
well I had my shit together ... pity the 'Drema hadn't followed suit, !!
More to follow on that subject .... a n other investigation session was going to be required!!
A few pix for yer's in the meantime, from Monday 19th.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/sheds/WP_20160920_13_59_56_Pro_zps0y6aabnp.jpg
run in was soft, shall we say ..... well softer than usual ... could certainly see where I'd been..
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/sheds/WP_20160920_15_06_25_Pro_zpsgkjcrsup.jpg
But TBH, firmer than I'd expected it to be after the Saturday & Sunday night's deluges
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/sheds/WP_20160920_15_06_55_Pro_zpsaqvnem1o.jpg
the two local builder lads he'd had come and do the pads and return today to assist in erecting it, were good boys, fairplay ....
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/sheds/WP_20160920_15_07_17_Pro_zps8vfekrl5.jpg
the fact that I'd made this originally, damned near 17 years ago helped too!!
Plus I'd been careful taking it down when I cleared my yard ... went back together a treat.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/sheds/WP_20160920_15_07_43_Pro_zpsqmm6xujn.jpg
just the lid left to go back on .....
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/sheds/WP_20160920_15_07_11_Pro_zpsd1igwxzg.jpg
which was on, welded and cleared up by 5 o'clock ... Not bad for a 1 o'clock start
He's gonna put a pole 'goal post' 4 m, in front of it, a few purlins from that to the compound, then sheet the whole lot ..... will give him a 7m wide and 8m deep traccy/implement shed, for next to sod all ... other than the cladding and the builder boys couple of days ... bit of cladding to the sides .... job done !!
Oh and the doors'll be swung out to form the sides between the pole goal-post and it, once they're clad
The 'Drema'd been fine for an hour that morning, getting ready to go down next door, to stand the old compound ....
squared a few things out the way, VA-r off, straight/big forks on and the 3 ft Geith hung on 'em .... (never forget Massa Yoda's words - a great guy on the UK forum ..... go nowhere without a bucket to hand ... never know when you might need it to get you out the shit)..... extra chains, slings, welder, etc. onboard and set off ..... only to have the bloody drive fade out .. stop, go, fade ..... FFS
Switched her over from digging mode to travel (isolates all exc. functions) and seemed 'better', so set off again .... got there and switched back to exc. mode ...... OK 95% of the time, but still losing it occassionally.
With my new found 'insights' into 'the system's intricacies' and knowing a little more of what to listen for ..... I was 99% willing to bet me right nut (I'd already bet the left one on Martyn's wire-wound resistors earlier in the week on another thread on the UK forum) that it's an LS system blockage .....
pump was not loading the motor at all ..
fades out as LS pressure drops off and then, until you release whatever motion you're using and dump the residual LS pressure in the MVB, presumably behind the blockage, to allow it to shift, then 'go again', .. there's now't and no load on the pump, as it's been down-stroked, by the lack of LS pressure to upstroke it!!
" bloody clever these pumps are "
Hopefully, I was going to be a step closer to finding it .....
First job the next morning ...... LS line off at the pump, drain the main valve block with it, get it off and blow the bugger out, then get the union out of the MVB and hopefully find two orifices in the union
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/Hydrema%20Troubles/WP_20160912_15_11_32_Pro_zpsz0cbj3qg.jpg
I reckoned two of 'em had to be in this hex nipple ... third might be in the end of the LS line at the pump ..... it was a queer looking male end on the line
Had it out Tuesday and another masterful piece of Rexroth engineering it is too.
this is what I had out of it, with a back blow of 150 PSI air.....
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/Hydrema%20Troubles/WP_20160921_13_13_03_Pro_zpsrse1xzip.jpg
before stripping it ....
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/Hydrema%20Troubles/WP_20160921_14_33_08_Pro_zps4qszfc1j.jpg
0.6mm followed by 1.2 mm all housed in an M10 assembly with a 3 mm exit throttle.
all the LSs feed the pump's upstroke circuit through this unit.
I also had a damned good 'fish about' in the port it lives in with a fine probe ....... and had a rubber crumb out ........ which I promptly dropped, 'fore I could get a pic .... wasn't much, maybe a mil an' a half max.!!
I'd also blown the LS line from the LS port/throttle assembly to pump's LS port at X through with the air line ..... obviously disconnected both ends, into a catch .....
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/Hydrema%20Troubles/WP_20160921_15_46_55_Pro_zpssx3bipzm.jpg
and got sod all other than Plantohyd in the catch.
needless to say it was all surgically clean when it went back together.
this fiddly shit takes some time, especially jammed in the bowels of the old girl, being ultra careful not to lose/have anything unforeseen escape!!!!
Anyway .............
Got it all back together and ran her up .... left her warm up for five whilst I crawled all over looking for leaks/drips/etc. .... now't !!
so .... gave it a go ..... picked her up from park, wrapped her up and swung her round so's I could get under her/at the arse end, to clean up all the oil in the 'pit', under the MV block .... carefully as I'd left her running to warm up.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20160921_17_30_18_Pro_zpsjonixp4f.jpg
Things were better but a little erratic to start, which I put down to the copious amount of air I'd introduced into the LS circuit by completely draining it and those throttles weren't exactly huge to deal with it, even with all the pressure in the system.
Stuck a bucket on her and worked her 'light' to start with ..... getting better !!
to the point that I had to give her something to challenge her ..... enter some dirt and a few boulders ...
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20160921_18_31_47_Pro_zpsqempdzqm.jpg
dug well, ripped this out ... no sweat ......
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20160921_18_32_01_Pro_zps72z4dlkd.jpg
and slung it about, with ease.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20160921_18_39_54_Pro_zpskpnhky0k.jpg
pretty fair lump and was ripping beds off the top, as per 'normal'
I'd say ..... very cautiously ..... the beast was back!!
Travel was also now, as was, harsh/sharp, aggressive even ..... as she was !!
Remained to be seen how things were the following morning ..... hopefully it'd be dry enough to get her up the ramp and do a 'bit more damage' to a few more boulders and 'shite' !!
She really felt like the m/c I've gotten used to these last 2+ years and handled roughly would leap about as she always has. Handled smoothly ... some tool !!
If she ddi it again ........ I knew the first place to look next time!!!!
I'll be surprised if it doesn't .... where there's a crumb ......... there's probably more ..... having said that .....
the amount I had out of the old return filter, wasn't huge and the amount I had out of the new return, a few weeks ago was minimal really.
We would see !!!!!!!
Again a case of Watch this space !!!!!
as Vinny Jones'd say (another well known welsh man) ......"It's been ............ emotional"
I've learnt a hell of a lot .... could've done without the OMG moments and stress of it all and would've been even better if she'd decided to have a wobbly on the patch, instead of elsewhere.... after I'd finished doing what I was about at the time.
Ground up there was still
Was going to give her a further work out and if she behaved, then go see what could be done to finish the original job ....... it was gonna be messy though ....... 'less I could find summat a bit harder to stand on, under the sludge/cheesecake topping
a few pebbles from the day's ripping sessions
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20160922_17_45_34_Pro_zpssuhsgusq.jpg
once I'd gotten it on the bucket ... it took some doing anything with ...and keep both axles on the floor !!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20160922_16_40_22_Pro_zpsnhkk6dgo.jpg
It was a toss up which was the heavier
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20160922_17_46_15_Pro_zps8t96wnno.jpg
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/WP_20160922_16_40_07_Pro_zpsubwgokrw.jpg
