well the conversation with Mog was had and he gave me a real easy way to get me FLT mast plumbed up, so it was a shopping trip to
hydraulic heaven son for a few weird
fitting converters ..... bloody Jap fittings .... and hopefully a bit of a try out thereafter!!
Shopping trip was had and wallet lightened by 'enough' - didn't have two fittings I wanted so we had to 'improvise', otherwise I'd have had to go back again today - 30+ mile round trip for two fittings didn't appeal
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/Druidfab%20VA%20Rotor/WP_20150625_18_12_59_Pro_zpshk9ydfc7.jpgthe fittings I wanted (and they didn't have) were to enable me to swap the weird screw together QCs, on't drema dipper, for some 1/2" FFs so had to make up an
adapter for now and I'll pick up said fittings again, but it did mean the hoses ended up a foot longer than planned ....... for now anyway !!
and so to ...... the mast ........
Got myself an adapter, from the FLT mast cylinder port (JIC apparently, not Jap. metric), to get me to BSP. I'd already sussed that one of the 3/8"
tilt hoses, that I'd replaced with quarters, when I was plumbing the VA-r finally, would be perfect for the job, so suitable fittings were acquired/pulled out of stock and said pipe persuaded into spot.
Getting the cylinder port fitting back in was a tad 'testing', but got there in the end ... took some getting out in the first place !!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/buckets/WP_20150626_16_51_23_Pro_zps97ybbpdm.jpghaving sussed t'other end, a suitable
bracket was created for a b/head fitting .......
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/buckets/WP_20150626_16_51_11_Pro_zpskxapkzqv.jpg........ welded into spot and 'tar-ed' before the plumbing went in
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/buckets/WP_20150626_17_22_38_Pro_zpsxghfiepl.jpgprior to getting picked up again, off the bench,
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/buckets/WP_20150626_17_31_01_Pro_zps7vkzni3y.jpgand onto the floor for a try .........
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/buckets/WP_20150626_17_45_04_Pro_zpsaj83dwkn.jpgMog's plumbing solution was even easier than I'd originally recalled (he'd been catering for it being permanently plumbed into the system with a diverter
valve) and was a simple case of returning one service
direction straight to tank, whilst using t'other, to provide
oil to the mast cylinder.
So a tank return was required and the easiest solution for a try out was the breaker return - looks a bit 'Heath' ATM as I was just using what I had to hand, to get it there. A neater solution will be forthcoming!!
Plus as I say I'm short on two metric/BSP M/M adapters from my shopping expedition !
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/buckets/WP_20150626_17_44_42_Pro_zpsq7e2kng5.jpgIt did however produce the desired effect!
Rotate
pedal forward and up goes the carriage ......
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/buckets/WP_20150626_17_50_09_Pro_zpsz3obs1h1.jpgPedal back ........ and after an initial pause, where I'm thinking
"bollo .... it ain't gonna happen", it quietly returned to the mast base.
The return was also better when the engine rev.s had dropped back to idle ?
Need to get me test weight down from where it's sat and stick it on there.
I was reluctant to take it full up, without a tonne, or more on it, to get the lil' b****rd back down
It also appears to have some '
air' issues, which a good amount of weight is going to hopefully 'iron out/dispel !!
This mast hasn't been used in 5 years, or more, so everything's a bit stiff. Chains have all been off, soaked and oiled and re-fitted, but until it's up, all the rollers are inaccessible for some lube and TLC
Also, having the mast on the floor and the
oil tank 10 ft above it, returning through the filter top, probably didn't help, so it could well perform better with it in the air a bit, or as I say, with a bit of 'gravity assist' in the form of a 1200kg test weight.
The eagle eyed amongst you will have spotted that when I piped up the VA-r with its new hoses, I'd put a QC on the tank return port, as I wanted to 'borrow it' to give this 'un a try.
The pipes, as seen, are long because, as I say, I was some fittings short to alter the 'Drema's QCs on't dipper, which'll re-position the QCs a foot or so, further back up the dipper.
I'm still considering whether to do the same to the P port on the VA-r, (put it on a QC), so's the plumbing can get stuck away, in the dry/out the weather, whilst not in use.
It's currently 'hard plumbed' / fixed.
I realise that the more QCs, the more chance of a leak, etc., but it has its advantages, for me !!
Plus, with Jack at Holmbury back on the scene, with his bargain Holmbury FFs, I'll probably replace all the ISOs with FFs and they drop so little on the change, it's a negligible issue.
Any thoughts guys ?????
