FMV 1800 crane
22 inlägg • Sida 1 av 2
Tumphu (trådstartaren)
#1 » 16:32:59, 10-05-2017
Hi,
I've seen most of here are Swedish, but i tought i'll ask help from here too.
Does anyone have any info about FMV 1800 crane? I've bought one old crane, it has some problems with control valves (and some missing parts too) and im searching parts list for that.
Does anyone have this partlist, or name of company /person that could help me with that?
Tumphu
Suomi Finland (finska)
Maskin: Ford 5610mk2 4WD
Ford 3000
Köpings S7C, year 1928, No: 25
raggsockan
#2 » 18:35:38, 10-05-2017
hello
welcome to the forum
i found this , not sure if it helps
http://www.solhem9.se/broschyrbank_skog ... V_1800.pdf
raggsockan
Maskin: volvo t24-53 .lik
irus u900
canadia
gilson
nissan d21 96 turbo diesel
subaru legacy 92
ett schysst järnspett
#3 » 19:04:58, 10-05-2017
That helps a alot! Thanks!
I havent even found specs for this. Alltho my swedish language isnt so good, so i cant seek info from forums or with google.
Thanks!
Tumphu
Ford 3000
raggsockan
#4 » 19:06:41, 10-05-2017
we can help u translate if there is eny words that you are wondering abbot
raggsockan
irus u900
canadia
gilson
subaru legacy 92
#5 » 19:18:59, 10-05-2017
Thanks,
At the moment im looking info about the control valves and spare parts for that.
I assume FMV were using some common manufacturer hydraulic valves, so maybe there are some parts and gasgets available.
That datasheed you've linked, seems to be dated 1978 so i assume these models were made late 70s to early 80s, maybe even late 80s.
It seems to be nice and tiny for small tractors that were mostly used around that time.
Hydraulic pump capasity need seems to be little too (15-20l/min) which also points to that age (my Ford 3000 -68 has around 18l/min flowrate).
Another reason for small need is the size of crane.
Tumphu
Ford 3000
#6 » 19:24:00, 10-05-2017
This crane i bought, is welded to small truck bed, so all attachment points are removed. Also support legs are removed.
Im trying to find good pictures to see how things have been when its been new, and also figuring out how to remake them today (maybe wiser than they were then).
Tumphu
Ford 3000
raggsockan
#7 » 19:27:05, 10-05-2017
some picktures of urs crane woudent hurt :grin: :photograph:
u know , we love picktures here :)
raggsockan
irus u900
canadia
gilson
subaru legacy 92
Bengt Erik Eriksson
#8 » 19:36:22, 10-05-2017
Hello!
About the valves. Can you take some cliseup photos of te valveboard? I guess there will be a lable at either end piece.
Bengt Erik Eriksson
Maskin: AVANT 218 -11
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
#9 » 19:55:49, 10-05-2017
Here are some pics that seller sent me. At this point i dont have the crane at my yard yet, transport company will deliver it some day soon (i hope :D ).
Bild Bild
I've got couple pics about the valves. I asked seller to see if there is any print / text on the model label. In pic we can see he has scracthed scrab out of it to see if there is text, but
as he didnt notice anything and didnt clean it more I assume there werent text left anymore.
Bild Bild Bild
On Ebay, these new 4- spool hydraulic valves doesnt cost much, like 150€ (around 1500Kr) including delivery.
These new valves also has this "Open center system", so all the time hydraulic fluid flows from pump to tank and it only uses small control pressure.
Only when needed, it takes more pressure from main line. Not sure does this old, original valve has the same system.
My Ford 5610 has around 70l/min hydraulic flow, so i assume it will need this open pump-to-tank line that oil wont warm too much.
Gladly I have this Deluxe valves on Ford, so i can change flow rate from switch, but not sure is this slower flowrate enough.
Tumphu
Ford 3000
MN
#10 » 20:08:57, 10-05-2017
you need 5 spools...
MN
MN
#11 » 20:18:46, 10-05-2017
True... Sorry i always forgot that rotator...
Yea, 5 spools is correct
Tumphu
Ford 3000
P Andersson
#12 » 20:30:22, 10-05-2017
The hydralik valve you've got is a 5 spool Monsun Tison HV07, almost every FMV crane used these valves at that time.
I'm 99% sure it's made for open center system, other systems were more expensive.
Remember that the tractors hydralik flow is ratad at max rpm, so at lower motorspeed it probably would work just fine
Bushen utanför Ryd, nu med fiber för ist tröga koppartrådar
P Andersson
Maskin: Valtra 6550
Hydrema 807
BM 650
Bengt Erik Eriksson
#13 » 20:38:35, 10-05-2017
Yes it is most likely open center in that valve package. In rare cases it might been converted to closed center. (ie used with a John Deere tractor) in that case it is easy to convert it back by removing a plug inside the outlet port.
As you se there is a manufacturer lable on the first picture. Unreadable att this picture.
Bengt Erik Eriksson
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
#14 » 22:25:17, 10-05-2017
#15 » 22:32:24, 10-05-2017
OpenCenter is probably the worlds most common type of valve because it is cheap and simple and works with a simple fixed displacement pump, like a gear pump.
However, a really cheap valve from E-bay will not have shock valves to protect the crane structure against overload. The fine control of such a valve may also be not so good because of poor design of metering notches in valve spools.
