Now, some explanations. FS20 got problem when it cought some very thin wire while I was moving down some bushes. Wire got draged inside the head and completely destroyed the
seal ring and tangled itself into bearing, damaging it.
Gear head is not easy to dismantle, takes some power but i manage to do it in my overkill vice (posted pictures earlier in this therad). I also replaced the bearing that carries the
clutch bell, it was not damaged but made lot of noise.
056AV Super is in horrible condition. She is very old and very worn out. The biggest problem is damage on the
housing where it leaks
oil. I tried to glue it wirth liquid metal and epoxy but it lasts very short. I have to replace membranes in carburator too. I can not even imagine how much work she did in her lifetime.
