I hope I have this in the right section as it has been an ongoing project for a while now, but is also an attachment for my machine?
Anyone who has read my intro. will know that I purchased a Hydrema Weimar M1500 last year, to replace a JCB 3CX, which had become 'outgunned' on a.n.other project of mine.
Well I also had a need to be able to rotate my forks that I had built for it, (another thread perhaps), so set about constructing a rotary device to fit between my Miller hitch and the forks.
I had, ?stashed away?, from way back; a rotator unit, that I?d acquired off the back of my scrappy?s truck one day, which had been attached to an FLT carriage with a long 12ft spike stuck out of it, which someone had managed to snap!!!!!
(In hindsight I should?ve had the spike too ? IIRC it was 70mm and ?kin hard!!!!!)
They?re used for handling rolls of carpet apparently?
Some pic.s below of a spike for attaching to forks and a rotator with a set of forks attached ? can not find an image of exactly what I?ve just described, but I?m sure you get my drift!!
So - the rotater - Many moons ago, in another life, I?d used said animal to make a bar bending machine for a large order, for 2000 x 20mm dia bar, odd leg staples for BWW for canal bank stabilisation, when I ran my fabrication business.
I don?t have a pic of the actual staples, with odd legs of 1000mm / 600 mm with a 30 mm rad. bend. but there?s a pic below of some shorter ones for a different job!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-11181416_zps1e10bbdf.jpg
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-11181501_zpsca690d69.jpg
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-11182047_zps6bc51bc1.jpg
I set about stripping the excess off the rotator, which had formed the bar bender unit.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-11191238_zps5c0e347d.jpg
Having sussed what needed to come off and set it out, in light of the heat from the gas axe, I reckoned it would be ?sensible? to get the ?ring gear? out of harm?s way and avoid cooking the seals on it.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-11214527_zps10cbf5dd.jpg
Thought it a good idea too, to have a good look at it, before going to all the effort.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-12163435_zps27f0f7b3.jpg
All looked fine, so the top plate came off, for a look at the pinion and ready to progress it.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-14131241_zpsf6b7ace7.jpg
Followed by the ring gear itself, after checking it for wear an? tear ? no lift at all!! (But then it hadn?t exactly had a hard life really!!)
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-14135028_zps2569bd3e.jpg
Gas axe time!!!!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-14135035_zps0a9461cb.jpg
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-06-14192851_zps091cf8d2.jpg
Well that slimmed it down a bit!!
Lot of head scratching went in to this bit, before ?sparking up? the torch!! Only had the one and didn?t want any cock ups!!!!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-08170928_zps50d42973.jpg
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-10192615_zps167b6a5e.jpg
Assembly time!!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-12124211_zpsa8488041.jpg
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-12134503_zps2254ae90.jpg
Having got it all positioned, tried and fine tuned/fettled, I got it all tacked up..............
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-12145010_zps3e2b980f.jpg
.................Enough to give it a trial fitting!!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-12152213_zpsf3d2a331.jpg
The front pin is only a 65mm as I didn't at this time have any other spare 70mm pins
Had to keep the pins ?high? to avoid the hitch making contact with the pinion housing, between the brackets/cheeks.
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-12152236_zpsa2d1a278.jpg
Looked a pretty fair fit, so knocked out a few more gussets and stiffeners, assembled ?em up ........
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-12163015_zpsc902b7c6.jpg
..............And got ?em in place!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-12164348_zps2645864f.jpg
Now for some very careful and planned sequential welding up, to stop the lil? bugger warping/twisting/generally getting out of shape!!
Originalets URL: http://i1275.photobucket.com/albums/y450/v8druid/rotator/2014-07-12201551_zpsd788ca89.jpg
