I am so bussy I simply have not a single hour of
spare time for months. Not a single free day for 2 weeks, worked yesteray and today for 16 hours straight. Yesterday we were finding and designing the route for new turbine
oil coolers piping trough the existing pipeline maze. Today we fought with turbine
shaft couplings, there is a minor "twist" between high
pressure stage, medium pressure stage, low pressure stage and
generator shafts (turbine is made out of 3 stages that are connected by rigid couplings. New bolts had to be made so every single hole had to be measured with
micrometer and angles checked.
Originalets URL: https://uploads.tapatalk-cdn.com/20210418/e8a5603c2d47675d833e1555ae560778.jpgLarge
gear behind me is used to slowly rotate the turbine and generator after the shutdown until they are cold enough via external 32kW engine with gearbox.
Originalets URL: https://uploads.tapatalk-cdn.com/20210418/04a52fb520c1b71a0d380527a28d0873.jpgOriginalets URL: https://uploads.tapatalk-cdn.com/20210418/18c2b100cc320ab824576bdef78fa02e.jpg
