Various restorations/projects from Bosnia
698 inlägg • Sida 38 av 47
selmir_Bosnia (trådstartaren)
#556 » 19:09:20, 26-06-2018
Hi all! I had some problems with my Husqvarna,2 bearings died ( there are 3 6002 and one 6203) so i changed them all.Quite hard to do it,everything is crammed and i had to heat head in order to dissmantle head.Bild
Originalets URL: https://uploads.tapatalk-cdn.com/20180626/2fb8c6e24e8b21fcdaab3edde68f1595.jpg
Originalets URL: https://uploads.tapatalk-cdn.com/20180626/229a11e7e95b894f138d3d05d2b4ac0e.jpg
Sent from my A6 using Tapatalk
selmir_Bosnia
Ort: Bosnia and Hercegovina, Ugljevik 76330 Janjari bb
Maskin: IMT 539
Zetor 7045
Hako Hakorette+ACME 8HP engine
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#557 » 07:35:45, 27-06-2018
What do you think about this tracor, are there Zetor/Ursus combos any good?
https://www.olx.ba/artikal/22892947/tra ... rursus914/
I have an option to change my Zetor 7045 for this Ursus 914.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
Bengt Erik Eriksson
#558 » 07:38:24, 28-06-2018
Yes they are good. Very good pullforce. Not so good steeringangles and, as far as i know, no differential lock i front axle.
Just beware of not driving in road with 4wd connected. I destroyed my zetor 10045 -83 in that way -95. Got a crack in the gearboxhouse bottom. Replaced housing but something went wrong and it made the oil bronze filled wich lead to differential breakdown. Then i gave up and replaced it. But it still runs somewhere since it was repaired.
Bengt Erik Eriksson
Maskin: AVANT 218 -11
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
#559 » 07:42:48, 28-06-2018
Thank you Bengt! I never use 4WD on road even now with 7045, only on fields. I like this 914 becouse it would be very good for deep ploughing (you remember that I have soil that tends to compact) so deep ploughing helps alot in drought. I will go to checkt this tractor as soon I get some spare time, will keep you updated.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#560 » 18:58:47, 28-06-2018
I went to check that Ursus.Engine and all mechanics are fine but tires are very bad and old. We did no agree on the price either,he wanted my tractor plus 2000 eur.Bild
Originalets URL: https://uploads.tapatalk-cdn.com/20180628/303c34b20a48cde730afa3106808d146.jpg
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#561 » 21:01:40, 05-07-2018
Maybe låter or was he sure about the Price?
#562 » 06:33:54, 06-07-2018
No, he was very hard on price. By the way, tractor had some issuses. Steering is not OK and there are welds everywhere, even PTO shaft was broken and welded...Poor machine had a very hard life as it seems.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#563 » 06:40:13, 06-07-2018
Had to make hand lever for steering brake on my Rasant mower.Original was made of aluminium and broke so i made overkill replacement out of steele.Bild
Originalets URL: https://uploads.tapatalk-cdn.com/20180706/dcb16d4f77bba4b5ad178eba7249faaf.jpg
Originalets URL: https://uploads.tapatalk-cdn.com/20180706/1d6ff95d506580dcbf46bdbb464c7c20.jpg
Originalets URL: https://uploads.tapatalk-cdn.com/20180706/ad660f0c0b7e01a34aa7d03383fa3e78.jpg
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
Glottis
#564 » 08:15:42, 06-07-2018
Good looking hand lever you made, nice work!
Glottis
#565 » 20:04:44, 06-07-2018
The best evening meal after a long day Bild
Originalets URL: https://uploads.tapatalk-cdn.com/20180706/8544d175ba83537a46c599da9c16262b.jpg
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#566 » 06:40:56, 16-07-2018
Some literature from Ebay Bild
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#567 » 17:57:23, 16-07-2018
Check out this beaty!Bild
Originalets URL: https://uploads.tapatalk-cdn.com/20180716/7678b5898b4fe2414317672f5b6638d1.jpg
Originalets URL: https://uploads.tapatalk-cdn.com/20180716/1ea169184b51b3d1ee41c411c9a106ab.jpg
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#568 » 12:52:02, 19-07-2018
I found this bad boy per pure chance.Ancient Stihl FS 022 with 61cm3 and 5.5HP. It is heavy as hell,12.6kg but works like a charm.Beautifull old machine just as I like it.I t was only 50 euro.Bild
Originalets URL: https://uploads.tapatalk-cdn.com/20180719/bfb863e142c39243d047a3675d32d71f.jpg
Originalets URL: https://uploads.tapatalk-cdn.com/20180719/0ac850adf995325e0c1b7556c30ea292.jpg
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#569 » 21:16:13, 26-07-2018
Just look at this old bad boy! Zetor 8045 Crystal from 1980., found it for my neighbour. Some guy imported it from Slovenia, gave it some service and paint but never ever used it in 5 years. It just sat there covered in blankets and plastic sheets. At first I was sure it will never start yet 110Ah battery brought him back to life. It is in astounding condition, steering, engine, brakes, hydraulics and 4WD are working perfectly. Only problem is PTO, it does not engage. I am not sure what my friend will decide, will he buy it or not.
I wish I had the money to buy it just for the joy of restoring it to his full glory.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#570 » 21:53:43, 26-07-2018
Right click on the video and copy the link from there and it will work.
