Various restorations/projects from Bosnia
698 inlägg • Sida 45 av 47
Blommas
#661 » 20:07:37, 03-07-2020
It works but I would never use a machine like that. The risk of loosing a finger or two is imminent.
Blommas
selmir_Bosnia (trådstartaren)
#662 » 09:56:28, 15-07-2020
True, it is extremely dangerous machine. I already used it to split 10m3 of firewood without any harm but I need to be 100% aware of where my hands are in every single second.
Btw, new project. I am using air transporter for filling of my corn silo (there is some info on earlier pages here) but i lacked the cyclon on the end of the transport tube that should slow the corn down and remove dust. Since there is no way to find and buy one that fits (my air transporter is a bit overkill with 200mm diameter pipes), I decided to make one based on images I saw on web. I used piece of 200l oil barrel and various pieces of junk sheet metal. It is not very nice looking but it will do the job. I found one on much smaller air transporter (100mm diamtere pipes) here in village (guy I know owns it) and used it as an example. There is lot of work to do, I need to close the side and mount grid that will allow the air to go out.
selmir_Bosnia
Ort: Bosnia and Hercegovina, Ugljevik 76330 Janjari bb
Maskin: IMT 539
Zetor 7045
Hako Hakorette+ACME 8HP engine
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
Holger
#663 » 12:13:43, 15-07-2020
Nice to hear from you Selmir! Stay healthy and safe!
Holger
Webmaster
Webmaster
Maskin: Test
texas5020
#664 » 07:06:19, 16-07-2020
It is amazing what you achieves with almost nothing in material, you´re DIY personalized ! A real genius to do anything out of nothing with your skills ! :buga: :thummar: :shake_hands: Take care of you and your family Selmir !!! :shake_hands:
texas5020
Hanomag B8 B lastmaskin
Harley Davidson Road King -05
Lambretta LI 150 -60
Husqvarna Rider
m.m...
#665 » 21:47:14, 12-09-2020
Hi guys!!
As usual, I am soo bussy but had lot of projects going on, I will try to post some pictures in next days.
One quick question!
I have an option to change my Zetor 7045 for a Zetor 8011 with front loader. So 4wd for a quite stronger 2wd (65HP vs. 80HP). What do you think about it, is 8011 a good replacement for a 7045? All implements will remain the same (2x14" plough, 2.5m power harrow). The reason I think about replacing the tractor is front loader (it is must have really, I have to ask my neighbour to lift something for me all the time), 8011 is stronger and the most important, I whink it is more agile - 7045 takes extremely lot of space to turn so I can almost never use it with trailer since It is very hard to make any maneuver and my yard is very small.
This is the tractor I am interest in
https://www.olx.ba/artikal/38782074/tra ... -tip-8011/
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
texas5020
#666 » 07:07:40, 13-09-2020
If your fields is not to steep and wet I guess it´s a good idea and it´s awkward to ask others for help all the time you need it. But I prefer 4wd all the time both with cars and tractors for the traction in both mud and snow and when you´re pulling something, besides you don´t need so much power. :shake_hands:
texas5020
Husqvarna Rider
m.m...
PeterR
#667 » 07:24:44, 13-09-2020
I would recommend to stay with the FWD as you plan to keep current machinery. Far better traction in the steep hills. Keep in mind: you know what you have, but not what you can get.
Why not build a front loader for your tractor? You seem fully capable to pull such a project?
PeterR
#668 » 13:25:21, 13-09-2020
FWD AND Front end loader !
You need FWD, today and tomorrow, the last floodrain is only a few days in the past :) next time is it the same problem.
Bengt Erik Eriksson
#669 » 10:38:17, 14-09-2020
I'd to say stick to 4wd. get a loader for the one you have.
8011 is a completely different machine than yours. and id prefer it but i still say stick to 4wd.
Bengt Erik Eriksson
Maskin: AVANT 218 -11
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
#670 » 11:41:34, 14-09-2020
Thank you guys for good advices, I will listen to you and keep away from 8011, you have the point, it is strong but 4WD is and will remain more usefull in bad terrain than much stronger 2WD.
Btw, here you can see some of my latest projects.
Here, I made forklift for my 40HP IMT539, completely out of scrap as usual. Forks are made from leaf springs from a heavy truck, rest is random junk I found/bought here and there. It will be used mostly forwarpped round bales. Forks can be removed and it seems that it was a good idea to make them so since I have idea for my next project.
Second, I got fed up with problems with my trailer tires. In last 20 years I am having some problems with tires. My father bought some used ones but they broke due to their age, then some pick up tires with only 6PR and when they died we bought used military Hummer tires, they were good but age got them too. Then we bought some new ones made in Turkey but they proved to be shit quality.
One day I simply decided to do my sort of solution for a problem. Total and complete overkill.
I bought two 385/50R22.5 truck tires with 20PR and 4500kg max load per tire (load index 160), then bought two steel wheels (11.75"x22,2") for them with zero offset. Friend of mine made two adapter plates according to my drawings, I welded them adapters to the wheels, mounted them on the trailer and that is it. These bigf tires are very cheap (20-30 EUR per piece) and can be bough everywhere even if I manage to break them (I can not load more than 4 tons in my trailer so I highly doubt it).
Yes, they are maybe too big but they fit nicely and look sick :)
Also, is it true you got bad and cold weather there? I heard so in news. Here we have drought again, it is very hot (35C and more) and no rain in last 4 weeks and no rain in next 2 to 3 weeks at least.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#671 » 11:45:06, 14-09-2020
About the loader you mention, what do you think about this soulution?
https://www.olx.ba/artikal/39718452/uto ... a-grajfer/
I coud make something linke this for my small tractor, it is more agile so I could maybe use to to load manure and not do it by hand anymore.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
Bengt Erik Eriksson
#672 » 12:04:46, 14-09-2020
I have a friend who use these. and he is verry fond of them. you get the load on the best axle and steering in the best end. The downside is the comfort and it might block the trailer hitch.
Bengt Erik Eriksson
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
#673 » 12:16:41, 14-09-2020
You mean the tires or the loader?
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#674 » 12:20:52, 14-09-2020
This is not s(crap) good idea of using this arms :thumme:
The forks give the bouncing roundbales a new meaning, with the potholes in the road you can pass the bales to your naighbour
Bengt Erik Eriksson
#675 » 12:42:23, 14-09-2020
the loader..
Bengt Erik Eriksson
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
