Various restorations/projects from Bosnia
698 inlägg • Sida 37 av 47
selmir_Bosnia (trådstartaren)
#541 » 11:54:42, 12-02-2018
Thank you Jac for this link, it was really helpfull to see this kind of experience shared openly. Old steering valve worked very strange under pressure, on one side it ran very hard with heavy load on engine, 4 cyl dizel with 55-60HP was starting to stutter under load before belt driving the pump started to slip. With new valve, that is not happening, it runs normaly, safety valve in steering unit works fine too, pump is not overheating, there are no strange noises. Problem was definitely with steering unit but I do not what it was, checked some drawings of orbitrol valves and they seem really, really, complicated inside so I am not confindent in trying to solve the problem myself, so i'll just sell it the way it is, maybe someone will try to repair it, it is brand name product, Danfoss with 150ccm per revolution.
selmir_Bosnia
Ort: Bosnia and Hercegovina, Ugljevik 76330 Janjari bb
Maskin: IMT 539
Zetor 7045
Hako Hakorette+ACME 8HP engine
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#542 » 19:25:49, 15-02-2018
I finally made it!!! Had to find new hydraulic cylinder, bought new one, finished the assembling 15 minutes ago and tried it all, it runs perfectly. I will post video later, had to upload it first.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#543 » 19:42:10, 15-02-2018
Here it is!!
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#544 » 22:27:10, 17-02-2018
Hi all, here you can see better video of Massey upgrade to fulll hydrostatic steering
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#545 » 18:34:40, 18-02-2018
I was very bussy this weekend, just chech this beauty, Sachs Stamo 281 built in 1962.!!
https://www.youtube.com/watch?v=LnL0agrNnDE
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#546 » 18:32:30, 19-02-2018
Hi all!
I have a quite weird idea, need to ask you about opinion. Look what i have found
https://www.olx.ba/artikal/23099698/zra ... soll-rand/
It is large Ingersoll Rand pneumatic drill for heavy duty work, it has MK5 chuck. I do no have and also never will have a air compressor large enough for this machine (it takes 4500 liters of air per minute) but i have an idea about converting it to electric engine, via belt. I would cut hole trough vane motor housing and use vane rotor itself as a belt wheel, would use 2kW electric engine with 3000RPM. Whole setup woul be stationary, some sort of drill press.
What do you think? It is quite cheap, only 25 EUR, i own electric engine and have a ton ow enthuisasm :) .
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
jörgen.ottosson
#547 » 21:21:02, 19-02-2018
That must be the "build of the Year" .....I sounds like fun.... :klia: ( is it really MK5, must be a monster drill then :uupps: )
But will you be able to get the RPM high enough to replace the vane motor, with out knowing i guess the RPM is quit high.
Deus ex machina
jörgen.ottosson
Maskin: sandvik sl-350
liebherr a500s
scania lbs 140
KL 121B
#548 » 22:51:45, 19-02-2018
RPM is making me headaches too. Do not know the speed of vane rotor but i am aware that it must be very high in order to get extremely high torque this kind of machines produce.
According to this parts list, i can count only 3 reduction sets, 2 with classic gears and one planetary set, it seems that it is the same or very similar model.
https://www.ingersollrandproducts.com/c ... _ed2_B.pdf
This is the same model, just a little bit faster. just check how much this thing cost as new!!!
https://www.intlairtool.com/ingersoll-r ... -power-hp/
Acoording to data i googled, this is suposed to be model 551 S0 with 77 rpm on main spindle and 1200Nm of torque and 4.2kW at full load, some 40kg...Well, you know me, I love overkill machines :)
Just imagine drilling with this beast!
Now to real problems - it it produces only 77RPM with vane motor, it has some serious reduction inside it, minimum 3 steps so vane motor turns definitely at far more than 3000RPM i can produce with normal electric engine. Since you know how hardcore DIY fanatic I am, i already found soulution for this problem!! I have two angle grinders with damaged gearbox and great engines, one is small wih 1kW and 10.000rpm on grinding disc and other one is big with 6000RPM on grinding disc (230mm discs) .
Since they have 10.000RPM and 6000RPM on their grinding disc, their engines must have far more than that, at least 20-30.000 RPM. I could use that engine, get very high RPM on vane rotor (via belt) and achieve some speed at main spindle.
I think this is the weirdest idea ever, even on this forum :).
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#549 » 21:17:46, 20-02-2018
You need more things and tools ?
It's a teaser for you only, it was a few days ago, 40€
http://www.slag1.se/auction/
#550 » 14:06:26, 23-02-2018
I am tools addict.... :)
I was allways wondering something. There are few people here that sell various tools and stuff on popular internet store PIK.ba or OLX.ba and most of their stuff comes from Sweden. Now i realize that they buy all that stuff via these online auctions. YOu could not believe how much money they make by reselling that stuff. For example, i just found few items on this site Slag like drills. Whole lot was sold for 400kr, that is 78BAM or 34 EUR. Here they sell each drill separately for 1BAM per milimeter and there is like few hundred of drills in that lot!!! Oh my god!
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
Bengt Erik Eriksson
#551 » 17:20:19, 23-02-2018
Well, it seems they "carv gold with a Mora knife" then.
Bengt Erik Eriksson
Maskin: AVANT 218 -11
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
#552 » 13:06:50, 04-03-2018
Latest project, angle grinder stand. Unfortunately this grinder died, it worked bad for a while and today engine died completely.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#553 » 13:29:24, 04-03-2018
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#554 » 08:07:36, 07-06-2018
Hi all!! Here I am again, still no spare time for new projects... :(
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
rospigg
#555 » 17:43:21, 07-06-2018
Nice to hear from you.
A cutter I can recommend is 350 mm Ø like this
/Rp
rospigg
Maskin: BM 36-57
Volvo t25 med perkins 4.107
MF 356 "rullstol"
BM 640 -69
