ForumindexMaskinforumFartyg och fartygsmaskineriFartyg
Loke Viking
7 inlägg • Sida 1 av 1
Diskutera fartyg här
Holger (trådstartaren)
#1 » 13:54:42, 24-04-2014
Vad används detta skepp till?
Originalets URL: http://forums.pelicanparts.com/uploads22/loke+viking+5e778645+5824+4284+bee1+950f01596b551397769677.jpg
Holger
Webmaster
Webmaster
Maskin: Test
Gustavors
#2 » 15:33:37, 24-04-2014
http://www.marinetraffic.com/se/ais/det ... OKE_VIKING
Hanterar ankare åt platformar kan man gissa?
MVH
Gustavors
Maskin: Liebherr 901
Fiat 55-90
Polaris Sportsman
David Brown 1212
John Deere 1140
BM320
#3 » 15:39:58, 24-04-2014
Aha! Tycker den aerodynamiska utformningen av avgasrören är snygg!
Holger
Webmaster
Webmaster
Maskin: Test
Gustavors
#4 » 15:44:27, 24-04-2014
Holger skrev:Aha! Tycker den aerodynamiska utformningen av avgasrören är snygg!
Må de! som de säger i småland (Tror jag) Min första tanke när jag såg bilden på den var kort och gott. "Lego"
MVH
Gustavors
Fiat 55-90
Polaris Sportsman
David Brown 1212
John Deere 1140
BM320
#5 » 15:46:19, 24-04-2014
:grin:
Holger
Webmaster
Webmaster
Maskin: Test
#6 » 19:22:43, 24-04-2014
http://en.wikipedia.org/wiki/Anchor_han ... ply_vessel
http://www.vikingsupply.com/event/doLink/FAMID/287732
Anchor Handling Tug Supply (AHTS) vessels are mainly built to handle anchors for oil rigs, tow them to location, anchor them up and, in a few cases, serve as an Emergency Rescue and Recovery Vessel (ERRV). They are also used to transport supplies to and from offshore drilling rigs.
AHTS vessels differ from Platform supply vessels (PSVs) in being fitted with winches for towing and anchor handling, having an open stern to allow the decking of anchors, and having more power to increase the bollard pull. The machinery is specifically designed for anchor handling operations. They also have arrangements for quick anchor release, which is operable from the bridge or other normally manned location in direct communication with the bridge. The reference load used in the design and testing of the towing winch is twice the static bollard pull.
pulling hook X 3 ?
Cargo tank capacities and discharge rates:
Marine diesel oil 1 960 m3
Rate 2x250m3/h
Fresh water 1 250 m3
Rate 2x250m3/h
Drill water 1 270 m3
Rate 2x250m3/h
Brine 821 m3
Rate spec.g 1.8 1x100m3/h
Liquid mud 965 m3
Rate spec.g 2.8 2x100m3/h
Special product 2x96 m3
Rate spec.g 1.8 2x100m3/h
Dry bulk 4x60 m3
Machinery:
2xMAK 4000kW / 5440 HP
2xMAK 3000kW / 4085 HP
Total of 19 050HP (14 000kW)
Bollard pull = 210 tons
Loke (närmast) och Magne Viking släpar på Antony Flemming
Bild från torrdockan i öresund
Lite förskönande lull från http://www.sjofartstidningen.se/hart-liv-till-sjoss/
http://www.skipsfarts-forum.net/read.ph ... 82&page=14
Normand Ferking, West Phoenix og Loke Viking i Fensfjorden på Torsdag..
#7 » 20:15:44, 24-04-2014
Dom där kranarna med dubbla "stickor" hade passat bra i tråden för ovanliga kranar. Ser ut som en sticka har grip och en är till och köra kran med. Nästan för klurigt för att vara sant. :)
Återgå till Fartyg
